I am trying to build a rally type car to basically play around with and since it is just for fun, I am trying to to spend a whole lot of money on it. What i was wondering is what kind of chassis would be good for it? Right now I am just looking at getting an old TA02 roller and getting new springs, tires, and already have a clio body I am going to use. I figured with the beating it could potentially take at the Tamiya track in Aliso Viejo, CA that a sturdy TA02 would be ideal since they seemed about bullet proof in terms of overall chassis strength and drive train strength. What are some other cost efficient options? A TT-01, TL-01, etc? Thanks for any help.
Imho a TB01 or TB02 would make a better rally racer in terms of perfomance and spare part availabilty, so in the end also even more cost effective.
I suggest the TB-01, because you can get special rally parts for it to keep out the dirt. Tamiya have a rally kit out using the TB-01 with a subaru body.
I'd second the TB01 suggestion for all the reasons mentioned. If you can find the 'rally' version it has a neato lexan dust cover for the chassis, a steel centre shaft and the foam dust protectors. Hopups are (relatively) cheap and plentiful from Tamiya and third parties like Eagle and GPM. I've got a similar project on the go at the moment.
However I'd check the wheelbase on the Clio shell (if it's the Tamiya Williams one) as I think it was intended for a shortened FF01 (240mm) rather than that standard 'touring' 257mm of the TB01.
HTH. David
Well seems a TB01 is prefered. Like I said, I am not looking to spend a lot of money, so may I ask why not a TT-01? I am not sure what the major difference is in the two chassis since they seem to be pretty similar. I was looking at the Subaru WRC TT-01 today and it doesn't cost much, and gets me the rally stuff as well. But I am not 100% sure on that since I can't tell from the Tamiya site or any rides here. Some have the rally tires, others don't, but it is not a big price concern.
Yes I did see the orange Subaru WRX that you guys were talking about, but being in the U.S. it would cost me about $150 plus shipping charges, which puts it a little too high for something I am just going to screw around with on weekends and not be a serious racer with it.
Again, cost is a big issue here since this would be just for fun and not competition. I am working on competition cars, and there is no way I will pay that much lol.
I am not too sure here but I think the TB-01 or TB-02 may not be such a good idea for a rally car due to the ball diff....Its great for track but I dont think they will survive long on an off road terrain.....I am more in favor of a chassis using gear diff like the TL-01
Well I did some pricing today and it turns out with the work I would have to do to each one, the pricing would be about the same:
1) TA02: find a chassis, get a rally body(personal deal), rally tires, new wheels, and offroad springs: est. $125
2) TT-01: chassis($70), shipping($30), rally tires, new drive shaft: est. $135
3) TB-01: chassis($100-130), shipping($20): est. $135
With the price gap that small I might as well get the TB-01 and save a lot of hassle when looking for replacement parts and stuff over a TA02, and a better chassis than a TT-01.
Good choice as I saw a used TT01 in a LHS and don't know how long the el-cheapo plastic it uses will last, also screws were rusted, in general the quality is far below normal Tamiya standards.
quote:
id="quote">id="quote">
The TB-01 hs a gear diff, but the TB-02 indeed has 2 baal diffs in front and rear. I don't think that should be a problem on off-road cars, these days many buggies have ball diffs as well... But what would hold the TB-02 back from rallying is that it has no dust cover and may have too few ground clearance. The TB-02 is more designsed as a tourer.
I think the TB-01 is the only modern Tamiya chassis that is ment to be a rally car... MAny others are more designed to be a touring car. You could also try the rally TA-02, and the TL-01 - but I would still prefer the TB-01. Also, most modern TB-01's are fitted with full ball bearings! [8D]
I think that is likely to happen anyway, there is no need to try hard to get rid of your money... [:P]
It depends on your interpretation of 'off-road', I wouldn't call the TB01 an off roader at all.
I had a TB01 (Mitsubishi EVO) for 18months and it was well used. It is a very good, robust chassis - far superior to TL01. The dust cover is good too. Tough suspension and strong gearboxes. However, I found it lacked enough ground clearance to use properly off road. A gravel/dirt track was really its limit. Try and drive over a beach, dunes, mud banks, ruts or bumpy tall grass and it is just doesn't work. The saving grace is the wide smooth bathtub chassis and superb gearbox mounting design which provides a continuous skid tray the whole length of the car. The short suspension arms leave nothing exposed to get damaged either which is also a bonus. With a decent shell that wraps around the wheels you'll be hard pushed to damage it. Only thing that wears is the front complicated steering arrangement, I replaced mine a few times, got about 10hrs use on gravel track before steering got so much play steering became inprecise.
Overall though I'd thoroughly recommend it over any other modern Tamiya touring chassis for mild off road use.
Anything more serious and you'd be best with a buggy or do like me and fit a touring/rally car shell onto a 4WD buggy chassis to give you best of both worlds!
hi all
im gald that i'm not the only one making a rally offroader - Converting a TA03fs to a TA03F with a 2003 impreza shell. Ive made some alu battery and gearbox guards, when ive learned to add pictures i will.
just waiting for the bathtub for the 20mm longer chassis and 4 hub bearings, modlesport sent me ones that were too small for the shaft yet too big for the housing!.
james
quote:I think that is likely to happen anyway, there is no need to try hard to get rid of your money... [
:P
DOH! That was a typo, I meant I am NOT trying to spend a lot of money on it. however, like you said, I probably will anyways. I need to keep some money around for my TA04 to get race ready.
I don't plan on doing serious off roading, but the Tamiya facility in Aliso Viejo, CA does have a gravel type track that is perfect for rally cars. So while I wait for batteries to charge, it wil;l give me something fun to do. I figure with a TB-01 it would also give me a good chance to see how I like the newer Tamiya shaft driven cars since the last one i drove was a TA02. If i like it enough, I may have to sell the 04 for a TB-02. If I had the money, I think I would just get one of everything so I wouldn't have to think about it this much[:D]
quote:Anything more serious and you'd be best with a buggy or do like me and fit a touring/rally car shell onto a 4WD buggy chassis to give you best of both worlds!
Why wouldnt he rather leave the buggy body then as the thing with touring/rally bodies is realism but when you put them on a long arm exceeding buggy chassis that is gone [?]
Hi DJTheo, I can't speak for anybody else but I find most of the buggy bodies awful looking. I prefer the touring car shells even if the wheels stick out a little bit. Generally it isn't too bad anyway as all my thundershots run with 200mm Subaru shells and the tyres only protrude about 15-20mm each side. As the shell has to be fitted quite high up the mounts to allow for suspension travel it doesn't look that silly, or at least I don't think so. It is just personal preference but my point was that if you did want a rally car shell but needed a decent off road chassis then it is the best solution.
I took a couple of my subaru bodied thundershots to Clumber at the weekend so maybe a couple of the other guys who were there could tell you what they looked like in the flesh?
I'm just building a new M03 mini at the moment and that too has a wider track than normal, I'm using TL01 suspension parts which means the tyres stick out 7mm either side of the arches. Looks a little silly but gives far superior handling than a stock M03 chassis, cornering speeds are greater and the thing doesn't keep rolling over.
BTW I'm always up for a challenge. If anybody would like to put a TB01 based rally car up against my thundershot based ones I'll be delighted to try it. I would be happy to compare performance both on and off road. Maybe next time we meet at Clumber somebody could bring along a TB01?
quote:Hi DJTheo, I can't speak for anybody else but I find most of the buggy bodies awful looking. I prefer the touring car shells even if the wheels stick out a little bit.
quote:I'm just building a new M03 mini at the moment and that too has a wider track than normal, I'm using TL01 suspension parts which means the tyres stick out 7mm either side of the arches. Looks a little silly but gives far superior handling than a stock M03 chassis, cornering speeds are greater and the thing doesn't keep rolling over.
Of course each to his own, tastes are subjective, its just my personal perception that I preffer buggy bodies more then realistic bodies with protruding wheels, I want either fictive cars or realistic ones. I would also try to find another way to improve handling on a M-chassis, as I find their bodies too beautifull to cut and don't see the sense of a M-chassis if you make it as wide as a tourer, then rather get a tourer directly... I like the challenge more to improve it without making it wider. Many members here have already posted enough experiences and advice how to hop up a M-chassis to improve handling, but since you enjoy trying your own creations, why not? [8D]
Sorry if this is off topic - Actually DJTheo the reason I used the TL01 bits was twofold, 1)I got a stack of TL01 parts trees from ebay very cheap and also an M03 chassis. Thought I'd try and get them to fit together as I already had the parts. 2) TL01 parts 'seem' to be more common, cheaper and readily available even from my LHS. I found it more difficult to track down M03 parts cheap, certainly off ebay they aren't that common.
