Does anyone have any tips on how to get better clearance out of the front end of the F103/F103GT? I run on a super smooth track and the front end drags around. I am not sure how to raise the front a little bit since there is so little suspension as it is.
The 101/2/3 series cars were designed to run foam tyres, when the tyres wear down the front starts to drag, also the kit front springs go saggy after a while, you used to be able to get hop up spring sets which gave you 3 different rates to choose from and were higher quality.
Larger tyres/new springs are the answer.
