Hi Everybody!
I just got a wild dagger brand new! Before I put it together, I wanted to get a few things.
First I wanted to get an Mtroniks sonik4 truck esc because its waterproof,but it's limits are 2 X 27Turn motors. I have no problem with that. but where can I get two 27T motors, one with reverse rotation? In my Super Blackfoot I have a Trinity p2k2 27T. I like its performance in the truck, lot of torque in the dirt and hills, and still quick enough to have fun in the street, BUT it is a motor with fixed timing. Im looking for the same performance out of my dagger or better!! Does anyone have any suggestions for a good 27T upgrade with reverse rotation, or adjustable timing??? If not is there any way to adjust the timing on a motor that has fixed timing?
Also is there a place where I can order a complete set of aluminun parts for the dagger, arms, uprights etc.....
I am located in the US.
Thanks Mates!
Congrats on your dagger !  (if you want another check my trades [;)]).  Check here for motor suggestions:
http://tamiyaclub.com/CS/forums/thread/157743.aspx
If the timing is 0 degrees, then you just reverse the +/- wires on one of the motors.  (in the clod buster the special motor goes in the back I assume the dagger is similar).   Also, I believe the kyosho magnetic mayhems are around 27 turns and one comes reversed.
