Ok, another go at a TLT;
Custom cut chassis, servo mounts and shock mounts.
Front half of battery retention copied from Neo, rear end is all me
Laid down 'Pede tranny this time
Male connector sliders
Steel UJs on axles
4WS
LRP Truck Puller II motor (rumoured 80 turn)
Spektrum 6ch radio
Towerpro 995 servos
LRP ESC
Traxxas Big Bore shocks
Tobee wheel wideners
Proline Moabs
Ofna rims
Proline CJ8 shell (my last one)
Links are homemade, 4mm all-thread thru 6mm (4mm ID) alu tubing
Dubro ball ends everywhere
Locked diffs and ball bearings
Just need a bit of plastic for the bottom of the chassis to cover them screw heads
Wheelbase: 12 5/8"
Width:12"
Clearance under chassis: 3"
This one's a bit more work than the previous TLT - the gearbox needs some real severe 'modding' to fit
The gearbox is lying down in this one, keeps COG low etc. but to do that, a lot of gearbox material needs removing - should really have taken pictures :D
Really quite chuffed with it (again) housebrick vid soon :D
Andy those TLT setups you're doing are Sweet. Is the next one going to have you're face lasered into the side...lol
PS I don't like the wideners just so you know........
Nice move on the ali Pede U-joints, my Hybrid Beetle used to snap the plastic ones faster than my first marriage lasted!
Can't wait for the Brick pictures.
Mike
We DON'T want to scare people away do we?? [:D]
Mike
Cheers fella, but whassup with the wideners?
Only found the steel UJ's by chance - they need a ring cutting off the
axle end in order to fit, but you can finally really crank them down
and not worry about stripping the thread out like the plastic ones
MadMax - Bite me [;)]
It's just that with the diffs locked the servos seem to have so much
trouble turning the tires and the wideners seem to make this an
increasingly difficult task. However I understand the TLT axles are a
bit narrow. [:(]
I'll bet the axles on the new F350 Hi-Lift are wider and will be better suited for these types of rigs.[:)]
Mike
