For those who haven't seen the Tamiya web page for the new RC models being introduced at the 45th Shizuoka Hooby show, here is the link:-
http://tamiya.com/japan/hobbyshow/hobbysho...s0605/news1.htm
Just put this page into the Google language page for a translation. Tried to post the translated link but it didn't seem to work. Sorry if this has been posted already.
Kind of odd that the Sand Viper looks not a lot different to the Desert Gator[:|]
good link [Y] - you are right - that sand viper looks to be almost the same as the desert gator.  Good old tamiya up to the same tricks I see. Of course , that great Hi Lift truck is looking fanatstic and is a great breath of life [:D].
[ New product guide June ]
TB evolution 5
Top model TB evolution of shaft 4WD furthermore evolution. Most parts new were designed low for center of gravity which it is thorough on the basis of the encounter data conversion. Especially, it takes a second look steering system, linear actualizing steering wheel feeling e.g., appropriate Ackermann is set. The aluminum bulkhead of one somatotype is lightened, combat power was raised more e.g., the short span suspension arm of reversible type is adopted.
- 1/10 electromotive RC car series No.371
1/10RC TB EVOLUTION 5 (58371)
* Including the carbon frame of ?? 2.5mm and upper 2.0mm the carbon damper stay front and back new form. * Equipping front one way and the rear ball diff.. * Body and motor selling separately.
Around June 17thsale
June 14th dispatch
1 ? entrance several 4
62,790 Yen
(59,800 Yen in substance price)
Ford F350 high lift
The pickup track/truck which represents America, Ford F350 is appearance by the electromotive RC car. Reproducing the forum which is done grandly to real with the precise die. The front grille and the bumper made the plated part. In addition, using the metal part, it makes, the chassis which equips the leaf rigid suspension in the rudder frame, also withstanding fully. Loading the speed change possible 3rd gear missions while travelling, also interest of running is extraordinary.
- 1/10 electromotive RC car series No.372
1/10RC FORD F350 HIGH-LIFT (58372)
* Total length 492mm. * The slipper which protects the gear - the clutch standard equipment. * Full-time 4WD. As for suspension front and back leaf rigidity. * Also the installation of multiple function unit of selling separately is possible.
Around June 24thsale
June 21st dispatch
1 ? entrance several 2
39,800 Yen in estimate value
??? COPPERMIX sill beer (TT-01 chassis)
It is the electromotive RC car of the COPPERMIX sill beer which displays the form in the ??? festival of last year. Illumination of the headlight and the tail lamp adds more reality to running. As for the especially headlight the light to which the becoming green which makes HID of the actual car think applies is a special feature. Also the headlight case is prepared with another part, tightens expression. Reproducing the glamorous body to real with polycarbonate. As for chassis TT-01 of shaft 4WD.
- 1/10 electromotive RC car series No.373
1/10RC NISMO COPPERMIX SILVIA (TT-01 CHASSIS) (58373)
* Total length 444mm. * The logograph of NISMO and SUPER COPPERMIX etc., you prepare the unique illustration of the bonnet and the body side with the sticker. * Setting the radial tire to 5 these spoke wheels.
Around July 1stsale
June 28th dispatch
1 ? entrance several 6
13,440 Yen
(12,800 Yen in substance price)
Mobil 1 SC (TA05 chassis)
Super GT of this year in 4 rec suspensions SC430 which fight, the machine of team ??? being the electromotive RC car already, it appears. Reality reproducing the forum which consists of the dynamic curved surface, changes to the racing car fully. White the color ring where logograph of mobile 1 is largely drawn in the base is finished easily with the large-sized sticker. The chassis the high performance adopted isometric 2 belt drives 4WD and TA05.
- 1/10 electromotive RC car series No.375
1/10RC Mobil1 SC (TA05 CHASSIS) (58375)
* Total length 449mm. * As for each bulkhead the top and bottom block construction which is superior in maintainability. * To adopt one somatotype motor mount, improvement the center pulley and the support precision of the spur gear. * Full bearing specification.
Around July 1stsale
June 28th dispatch
17,640 Yen
(16,800 Yen in substance price)
Sand viper
The light running only of 2WD is the model of charm. DT-02 which the popular dessert gaiter - pulls the chassis and comes after. In addition to handiness, also setting is possible with the upper arm which adopts both screw shaft. Equipping the CVA oil damper, you show high travelling efficiency even with the rough road. In addition, as for the drive shaft and the joint cup the metal make whose strength is high. It raised also drive efficiency as a full bearing specification.
- 1/10 electromotive RC car series No.374
1/10RC SAND-VIPER (58374)
* Total length 384mm. * As for the body which it is ready low polycarbonate make. * The nosewheel installing the wide grooved, rear wheel of 27mm width the square spike. * As for front and back wheel design ray sea off load dish type.
July sale
10,800 Yen in estimate value
[ New product guide May ]
XB ??? R34 GT-R Z ??…??
It is the completion electromotive RC car of ??? R34 GT-R Z ??…?? which attracted the attention of Tokyo automatic salon of last year, was called ultimate GT-R. Vivid light LED light/write of charm standard equipment. Illumination of the headlight and the tail lamp engenders more reality. As for chassis controller bull TT-01 of shaft 4WD. Forum of force such as bonnet and wide the fender where the exhaust heat louver is cut is charm.
- 1/10XB (expert built) series No.51
1/10XB NISMO R34 GT-R Z-tune (57751)
* Total length 422mm. * As for light/write front and back regular illumination. * As for transmitter wheel type. * Back travelling possibility loading pseudo- controller "TEU-101BK". * 7.2V battery, charger attachment.
Around June 3rdsale
May 30th dispatch
24,990 Yen
(23,800 Yen in substance price)
XB sea bass swift super 1600 German '05
Last year keeping the sea bass, full swift super 1600 it threw to JWRC, showed speed is appearance by the completion electromotive RC car. Approximately you project the fender at once and reproducing the forum which equips the roof spoiler with high reality. Yellow in the base, the body where many sponsor stickers were pasted raises the mood of running. The chassis adopted nosewheel drive and M-03M of the wheel base 225mm.
- 1/10XB (expert built) series No.54
1/10XB SUZUKI SWIFT SUPER1600 GERMANY ' 05 (57754)
* Total length 347mm. * You set also the transmitter, the 7.2V battery and the charger of wheel type. * Loading ESC "TEU-101BK" whose smooth speed control is possible. * The tire installing 60D radial.
June 21st dispatch
23,100 Yen
(22,000 Yen in substance price)
XB ARTA NSX
It is the completion RC car of ARTA NSX which wins in the super GT 7th game of last year, attaches to annual ranking 2 rank. In addition to the forum of force of the low/row & wide, it reproduces to real to the door mirror and the large-sized rear wing of unique form. As for the chassis the maneuverability which does not have ?? adopted shaft drive 4WD of charm and TT-01. Putting out from the box, of course race/lace participation of ??? sponsorship it is possible to be able to play directly.
- 1/10XB (expert built) series No.53
1/10XB ARTA NSX (57753)
* Total length 432mm. * Setting the transmitter of the wheel type which is suited for the operation of the car, the 7.2V battery and the charger for travelling. * Back travelling possible speed controller "TEU-101BK" was loaded.
Around July 1stsale
June 28th dispatch
21,840 Yen
(20,800 Yen in substance price)
??????? hornet
New genre RC of compact size, ??????? 2nd feature is the hornet. As for the body of the color ring which represents the sparrow drumstick polycarbonate make. Slim & high intensity as for the chassis which adopts the monocoque frame 2WD. The ball diff. and the slipper - real equipment of the clutch and full bearing specification etc. is full load. It can enjoy continual travelling of maximum of 30 parts with the 7.2V-500mAh battery of attachment.
- RC ??????????? No.2
Tamtech-Gear The HORNET (56702)
* Total length 266mm. * The completion model which can enjoy running directly. * The receiver of just size, loading ESC and servo. * High efficiency 370 motor attachment. * Also the option part of selling separately being even, efficiency rise possibility.
Around July 1stsale
June 28th dispatch
20,790 Yen
(19,800 Yen in substance price)
XB side viper
Putting out from the box, it is the completion RC car of the 2WD buggy which can enjoy light off load travelling directly. It is low, to load the RC mechanic onto flat in the bathtub frame of center of gravity, the 7.2V battery center arrangement. The weight balance which is superior is produced. As for suspension the double wishbone 4 wheel independence which takes stroke fully. The tire equipped the front wide grooved, rear stud spike.
- 1/10XB (expert built) series No.55
1/10XB SAND-VIPER (57755)
* Total length 384mm. * As for body lightweight polycarbonate make. * Loading back travelling possible ESC "TEU-101BK". * You set also the transmitter of wheel type, the 7.2V battery and the charger for travelling.
July sale
20,800 Yen in estimate value
XB ???? frog
In the December last year ???????? which revival is done, is appearance even in the XB series of the completion RC car. The front double wishbone of inboard spring adoption, mounts the oil damper horizontally 4 wheel independent suspension of the rear trailing arm which produces the light running which the pleasure. It paints the humorous body in white and pink is divided, pastes also the sticker and it is being completed.
- 1/10XB (expert built) series No.56
1/10XB The FROG (57756)
* Total length 410mm. * Loading the x peck SP transmitter and back travelling possible speed controller "TEU- 101BK" of wheel type. * You set also the 7.2V battery and the charger. * 540 motor attachment.
July sale
26,800 Yen in estimate value
The FS-15S engine (aerodynamic volume displacement 2.5cc) liberal power and the large diameter tire of diameter 110mm going hand in hand, it is the completion engine RC track/truck which does not choose the place and can enjoy exciting travelling. Adopting the NDF-01T chassis which adopts 4 wheel double wishbone suspension of shaft drive 4WD and oil damper equipment. The muffler of the polish finish raises force. Loading the fuel tank of 75cc, in 1 tank 4
- 1/10 assembly being completed engine RC car series No.25
1/10XBG NITRO CRUSHER (43525)
* Total length 445mm. * Equipping FICS which protects the front suspension arm from the shock of 10001. * The high performance adopting the disk brake. * Transmitter attachment of wheel type. * Full bearing specification.
June 14th dispatch
44,940 Yen
(42,800 Yen in substance price)
OP.906 5x5mm aluminum hexagonal pyro ball (5)
... May
840 Yen
(800 Yen in substance price)
OP.907 5x8mm aluminum hexagonal pyro ball (5)
... May
840 Yen
OP.914 dish wheel white 4 (26mm width offset 0)
... May
630 Yen
(600 Yen in substance price)
OP.915 TA05 lightweight center shaft
... May
420 Yen
(400 Yen in substance price)
OP.916 TA05 aluminum stabilizer holder
... May
1,260 Yen
(1,200 Yen in substance price)
For OP.917 reversible suspension
f 2.6mm titanium coat suspension shaft set
... May
1,260 Yen
???????? V part for OP.918 TRF damper (damper color) 2
... May
525 Yen
(500 Yen in substance price)
OP.919 TA05 aluminum diff. joint
... June
1,890 Yen
(1,800 Yen in substance price)
OP.920 TA05 aluminum motor mount
... June
5,250 Yen
(5,000 Yen in substance price)
OP.921 < Temporary > TRF415 front aluminum diff. joint
... June
2,625 Yen
(2,500 Yen in substance price)
OP.924 DF-03 heat sink bar set
... May
1,050 Yen
(1,000 Yen in substance price)
OP.925 < Temporary > DF-03 slipper - set
... June
2,940 Yen
(2,800 Yen in substance price)
OP.928 short reversible suspension arm
... June
735 Yen
(700 Yen in substance price)
OP.926 DF-03 aluminum damper set
OP.927 DF-03 setting spring set
OP.929 ?????…?????? (27T)
Spare part
SP.1246 ??? R34 GT-R Z ??…?? spare body
... May
3,360 Yen
(3,200 Yen in substance price)
SP.1253 TB evolution 5 B part (bumper)
... June
735 Yen
SP.1254 TB evolution 5 L part (gear cover)
... June
525 Yen
SP.1255 TB evolution 5 one-way gear set
... June
483 Yen
(460 Yen in substance price)
SP.1256 TB evolution 5 ball diff. gear set
... June
483 Yen
SP.1258 ??? COPPERMIX sill beer spare body set
??????? option part series
OG.09 GB-01 aluminum diff. joint
... May
1,470 Yen
(1,400 Yen in substance price)
OG.10 GB-01 aluminum motor plate (pink)
... May
735 Yen
OG.11 GB-01 aluminum wheel hub (pink)
... May
1,050 Yen
OG.13 GB-01 aeration oil damper (4)
... May
Estimate 7,000 Yen
OG.15 GB-01 bumper set
??????? spare part series
SG.31 ??????? hornet spare body
??? RC system
45033 ??????? ESC TEU-102BK
... May
5,040 Yen
(4,800 Yen in substance price)
45034 TSU-02 servo (for ???????)
... May
4,200 Yen
(4,000 Yen in substance price)
Battery & charger
55094 ??????? hydrogen batteries
7.2V advance pack 3700HV
... May
9,450 Yen
(9,000 Yen in substance price)
RC limited commodity
49392 TB evolution 5 stubby rod sets
... June
945 Yen
(900 Yen in substance price)
49393 TB evolution 5 bis sets (titanium & aluminum)
... June
7,140 Yen
(6,800 Yen in substance price)
So a Tamtech-Gear Hornet eh?  I wonder how many of the classic buggies will get the T-G treatment.
And where does the "sparrow drumstick" fit in there?[:o]
The Tamtech Hornet was at the RCX show in California.  I have a picture but it's a bit blury.  If it's not too bad I'll post it.
