I have some 50672 5 spoke 26mm two piece rims and was wanting to know if the inserts from the 50673 wide rims and  mesh rims 50549 and 50548 could also be used on the rims and vica versa. i.e. are the chrome rims the same apart form the width and can all inserts be interchanged?
Are the 50548 rims narrower than the 50672 rims as the info I have is that the 50549 are 22.4mm whilst the 50672 are 26mm or are these measurements being taken from different places on the rim?
The same question applies to the 50549 28mm and the 50673 rim 31mm but I note these both take the tire 50547(5547)?
thanks
Disclaimer....I think Shodog is correct.  The insert will fit the different rim and can be insert at different side of the rim to give the RC a wider or normal stand.  The TA02-W, "W" stands for wide, have rims for this purpose.
Thanks for the replys - I opened up a set I have and it clearly shows that the narrow rims are either +2mm or +4mm offset and the wide rims are +2mm or +10mm.
