No, you will need a undercowl and many other parts to do it too. IT's best to look for a top Force and a TF Evo at first hand, on stead of trying to get all the options on a later date.
Also, the FRP/Carbon chassis shoudl be one of the last mods you do on a car, there is plenty of room for improvent to do before you will 'need' that. [;)]
Turnbuckles will jsut allow you to adjust the camber and toe angles easier (depends on where you use them of course)... [;)]
I find the normal adjustable rods often good enough. The Dirt trasher has sollid plastic upper arms that allow no adjustment, you could make you own adjustable links with some threaded shaft, a few balheads, and some creativity. [8D]
