Just tried to use this receiver (Acoms AR-227FE) and it doesn't seem to work though I'm sure when last used it worked.  Could this be because the servo's AS12's are not compatible?
The plugs on my other receivers appear to be exact size for the servo plugs/connectors; however, the AR-227FE receiver seems to have connection/fittings that are physically larger than the servo fittings, that said the servos still appear to fit it's just that there is a gap around them.
I'm guessing that the AR-227FE maybe an older (vintage) receiver for older servos with larger connectors?  Anyone have any ideas?
Redseven
