Fitting the light kit to the Knight Hauler, noticed a problem.....not enough lights!!
Missing 4 of the LED's....the ones that go in the front headlight clusters (side marker lights) and the rear light clusters (same thing).
Anybody know where I can get them? I assume they can go into the same terminal block as the roof lights?
Cheers from the Corpse.....
Hi if your trying to fit the old light unit (the open circuit board type) its not really for this truck you really want the mfu set which has the aux lights for the knight hauler.
Last year when I did my Knight Hauler project, I spared no expense and
bought the MFU and it was worth every dime.  When I opened it up,
I thought I was short one set of LEDs, but wasn't reading the
instructions correctly.  It all works so well, I'd consider the
MFU for the new High Lift F-350 as well.
At the time I didn't think the MFU came with lights.....and where I bought it from doesn't specify that its not for the Knight Hauler....and it definitely can be used, its just short 4 little LED's, thats all. The Knight Hauler has the cutouts in the back of the sleeper cab.
I'll go for the MFU on the high lift too I think.
Anyone know where to get these little lights?
Depending on which one's you need they will either be 3mm or 5mm LED's.  Just find one's that run on the same voltage as the stockers do and go from there.  But you won't be able to just buy a kit this is a DIY thing.
