hi running a team mtroniks vision series motor with 14x2 turns with a 16t pinion, just woundering if this is the best setup, and could i get away with fitting a 18 or 20 tooth pinion gear or would the motor overheat, cant see anyway to fit a heat sink, would fitting a standard 540 silver can and a 20t pinion be a better bet for top speed.
How hot does your motor get with the gearing you running
now?
You could just try the 18t or 20t
pinion and while driving the first time just stop and check the motor every
couple of minutes to ensure it doesn’t overheat.
You should also get the M03 heat
sink (since the FF02 is just a M02 with TL01 suspension and a spacer on the
chassis). Link
I don’t think your car will be faster with a 540 silver can and a 20t
pinion unless your 14turn is completely worn out.
Ole
