Simple question - anyone know if the chassis component for a re-re Grasshopper is different to the original model?
I have an original grasshopper at home that suffered a major impact
back in 1997 that finished it off for good.  Looking at a possible
rebuild, I've noticed I can buy a new re-re chassis for less than £10
(and probably enough spare parts to fix any other damage I come
across.  I was thinking of selling it, but this could be quite a
fun project over the coming months.
According to the manual the original 'hopper could use hump-packs or racing packs - does the same apply to the later chassis?
Cheers [:)]
The re-re chassis doesnt have the hump pack cut out on its whole length, so if you would want to use a hump pack you would need to do some cutting/dremeling. Old hump packs anyway don't work greatly after so many years and battery technology has advanced alot, so no sense imho in doing it.
cheers for the advice, seen some dirt cheap re-re chassis on ebay,
looks like there's enough there to rebuild most of the car with new
components!
Only thing I can't find is new tyres - anyone know of a place to try
for Grasshopper rear tyres?  Anything but those paddle wheels
won't look the same [;)]
cheers, found [:)]
Just gotta wait until he's back off holiday [;)]  still no rush - got the Pumpkin to build first
The newer diff casings are stronger, the bracing from the axles to the diff casing are larger, I have an original Grasshopper and Hornet and I compared it to my friends re-re Hornets and they had the bigger bracing...
I think the bigger ribs came already during production of original Hornet and Grasshopper (so there are 2 versions), also the LB/MP had them.
