Been doing this to TLT tyre foams for a while now
Without foams at all, they're a bit too 'mushy' and uncut foams just don't look good ;)
Plus, cut foams are a bit like running tyres on low air pressure - it gives a slightly bigger contact patch, and the tyre deforms easily around the terrain.
So, just got a new set of Moabs off eBay..........................
With new foam in, the tyre is really packed out - notice the convex shape of the sidewalls where the foam is too big for the carcass, so pushing the walls out;
Get a knife with a long sharp blade, at least the width of the foams
Eventually, I cut about 1/4'' off each side, but to start with, just take it off one side (to leave a flat face for the next step)
The Marking;
Start by dividing the circle into quarters
Then, eighths (that's 45 degrees)
Ok, now take a line from the top of one line to the bottom of the next (this'll create another marking point)
Take a line from that intersection, across the centre hole, to it's opposing intersection
Then, take a line from the top of the new one, to the bottom of each line either side
Ok, the less boring bit - cut from the outside into the V created by all those lines, being careful not to cut past the bottom of the V, leaving this;
With scissors, cut a small bit of each corner off, to give the tyres a more rounded profile (if that's what you want)
Almost done!
Turn foam inside out
Cut a small 45 degree chamfer around the edges (to allow foam to seat inside the beads better - a 5mm x 5mm chamfer is good for starters
Also, if you didn't already, shave the face with all the pen lines on it (the other 1/4'' from earlier)
Finally, turn it back the right way (points to the outside),put it back in the tyre and admire the concave profile of the tyre :D
