I am trying to find out where to purchase foam tires for a TGX or some info on what other brands would work? Can anyone help me?
There are a couple of types floating around eBay.  Neither of which are 'high quality' by most standards.
Both are discontinued so-to-speak.
GPM made some mounted with white 5 split-spoke type wheels. I've never personally used them, but I haven't heard great things about them
I've used some other generic no names that took some manipulation to fit, but worked OK.
They're actually made for the HPI Super RS4 Nitro, but I've found that they fit if you can find some thin type lock nuts to use.
The main issue with them is wear; they chunk pretty easily, so you have to use them in extremely clean, wide open areas/tracks.
-Steve
