Hay i have a prblem with me rebuilt Terra Scorcher, I have a stock speed controler the mecanica one not electical one but 1st and 2nd no longer seam to work 3rd works like a treat but i would like to be able to manuver at slow speeds. Does anyone know why this is happening?
Regards Trev
Either the wiring on the bottom has come adrift or the resistors have packed up!!
Now would probably be a good time to invest in an electronic speed control, you'll also get much better slow speed control and probably longer run time from your battery as an ESC is much more efficient
MTroniks esc's are good and they are also waterproof!!
It depends what you're going to do to the Terra Scorcher, are you going to fit a faster motor??
The best idea probably would be to get an umlimited esc that way if you do fit a faster motor you don't need to worry about it being too much for the esc
