I have 'aquired' a boomerang chassis, but one of the front holes where the bumper screws to is cracked (muchlike what happens to the falcon chassis)
whats the best method for sorting this out? superglue or something else?
just wondering as the chassis is better than the one i have already so would like to use it.
I have repaired many a damaged plastic part by using either clear or black epoxy 2 part resin .This bonds well if you can get get it to stay in place while it sets, as it can 'slump' or run - so you need to think about how you are going to do it before you mix , and depending on the make of resin ,they can cure at different lengths of time -ie , some are 5 minutes and some are 5 hours etc .Once cured ,you can drill it ,tap it ,sand it etc.,but if you can get a neat enough finish straight off ,you dont need to do anything else.
