I've got a new Parma lexan shell that I want to do a tidy job on -
unfortunately some of the technical bits (grill etc) are really
difficult to mask using the Tamiya tape that I have.  Who has
experience using liquid mask?
Is this the stuff that paints on and dries like rubber?  Is is
necessary, when painting it on, to get the lines perfect first time -
or do I paint it on, let it dry, then trim off what I don't want with a
sharp knife (taking care not to damage the lexan)?  Do I need to
use several coats of liquid mask to get a good seal?  What sort of
brush to I apply it with, and will the brush be ruined after coating,
or can it be cleaned?
Is is possible to mask an area, spray it, then take off some of the
liquid mask to continue spraying in another colour, then take the rest
off for a 3rd colour..?  I want the main shell to be yellow, but
with some black stripes and silver or chrome grille and bumpers.
Also - re painting - does anyone know of a good UK online shop or ebay
shop that sells decals, transfers or design masks for lexan.  I'm
looking either for a mask that I can apply to the inside of the doors
so I can detail it later once the main colour is painted - I know Parma
do some but can't find a UK supplier.  Either that or those
transfer things that stick on the inside of the lexan before
painting.  Again, can find US suppliers but not UK.
Finally - is there a good lexan chrome paint for doing ultra-shiney chrome grilles and bumpers?
Thanks in advance [:)]
Lots of questions.... ;)
I've used liquid Mask, I think it was Parma stuff. You aplly with with a paint brush, and as you say, its like a rubber seal/coating. You can trim once dry, so get it in the right area and make it neat when dry. You can trim, paint, trim, paint no problem too. Helger imports Parma stuff, I think I got mine from Microtech, but any model shop with a Helger account can get it.
Orion, Pro-line and some people on eBay do internal decals, some look great (Pro-line do good border decals for 2-colour paint jobs).
Alclad and Spazstix do chrome for airbrushing, and Alclad, Spazstix and Fastrax do chrome in a rattle can. use the whole amount of paint, then lightly back with black.
The best liquid mask available in the UK by far is Parma Fasmask,
available to order from just about any model shop. Goes on nice and
smooth and is easy to work with. It is basically a specially formulated
latex rubber. The way to use it is to put at least 3-4 layers on the
body.  In theory you could just use one layer, but it is difficult
to peel off as the very thin layer just breaks up. Use a soft 1/2 inch
brush and spread it on evenly. Leave each layer to dry before adding
the next layer. If you only put on one layer first there is the problem
that brush marks in the mask mean it might not completely cover the
shell and secondly it ends up coming off in very small pieces and you
end up scraping it off with a fingernail. Takes a bit longer than just
putting extra layers of mask on in the first place.
I use several techniques with liquid mask and there isn't a right or
wrong way to use it. If you have window masks fit those first before
using the liquid mask, they do make it easier than trimming the liquid
mask around windows.
Just paint the mask over the inside, then draw your design on the
outside of the shell with fine tipped marker pens. If the shell has a
protective film, these marks will come off with the film, if not use
alcohol to wipe off the pen lines when finished. Then use a sharp knife
to cut out the sections of mask on the inside. I use a scalpel for
this, making sure I use a new blade for every body. The blade must be
new, that way by drawing it lightly over the film it will split the
film. If the blade is even slightly blunt you will have to push on a
little harder, which will go through the masking and scratch the body.
I find it best to cut all the design first, mainly because it is a lot
easier to see what you are doing. Once your design is cut out peel out
the sections you need to paint by peeling it back on itself, this helps
to separate the sections and stops the next section lifting. If another
section starts to lift press it back down and it will stick again.
Paint and repeat as necessary.
For stripes that need a nice straight edge as it is difficult to trim a
straight line inside a bodyshell I first use a thin lining tape to mark
the edges, then use liquid mask over the area I don't want painted. In
your case before using liquid mask I would use masking tape to mask out
around the edge of the black stripes, then use liquid mask over the
rest of the shell. This would mean you can paint the black stripes
first and don't have to worry about cutting straight edges in the mask.
For the grille and headlights there are two options, each have their
advantages and disadvantages. First option, paint the whole of the
inside with liquid mask and cut out the lights and grille. This gives a
crisp sharp edge to the mask and usually a much straighter edge than if
you just painted the mask on. This gives the best finish if you can cut
the mask out. The biggest disadvantage of doing it this way is that
usually for lights and grilles you have to trim the mask along the top
of a ridge inside the shell which makes it very hard to follow the
lines, usually in corners that make it awkward to get your knife in. Do
remember though that if you mess up the cutting you can just recoat the
mask and try again when it is dry.
The second option, which although easier tends to give more variable
results. Just paint it on the lights and grille. I do use this
technique on certain bodies, for example on Scorcher repro shells it
would be impossible to trim the mask around the headlights properly
using a knife. Use a small brush to paint out the details, again paint
on 4 coats of mask. The biggest problem is getting the edges right. A
little trick is that if you go over the lines you can wipe the mask off
straight away with a clean cloth and can give a straighter edge than
just brushing. You can practice on your shell, remember if you make a
mess of the masking you can just peel it off and start again.
For precut paint masks Parma make a good range
http://www.helgerracing.com/j7parma/j7mask...7maskpage1.html
and like the liquid mask should be available to order from any shop
that deals with Helger Racing - if they sell Trinity or LRP products
they will have an account with Helger. The most common internal
graphics are the Team Orion ones, which can look pretty good if applied
with care.
http://www.mirageracing.com/productRange.p...ODY+subc%3ABDEC
Again should be able to be ordered just about anywhere with an account
with Mirage, which means any shop that sells HPI or Xray.
For chrome paint I have tried every one available and the best by far
has been the Fastrax Fast Finish Chrome, available from any model shop
that deals with CML which is just about every one.
http://www.modelsport.co.uk/?CallFunction=...mp;ItemID=23933
It's an aerosol, you don't need to use much as you can see the effect
building up after a couple of coats and is good enough to work without
any backing, unlike just about every other chrome. Whatever chrome
paint you use make sure you only use an acrylic paint or Parma Fascolor
to back it with, using a normal lexan paint will turn it from a
mirrored finish to a bright silver finish as it reacts with the paint
even after having been left for a while. The body below was painted
Fastrax chrome - see the aerial reflection in the chrome stripe. The
body is a Kamtec one and the surface isn't as flat as it could be,
which is why the reflection of my fingers isn't as sharp as it would be
on a better quality shell.
