I have heard about the plastic on the Novak esc series cracking from it. I use it all the time on Tamiya products, but I usually use water afterwards.
Guest joelvardy
if you do use i try to wipe it off the plastic
wd 40 WILL find its way down any small stress cracks in the plastic (usually found around screw and bolt holes. its designed to free off rusty bolts, so it easily finds its way down small cracks in plastic, which would otherwise have stayed small. the wd 40 then lubricates and opens up the crack and causes the part to fail.
thats my experience with wd 40 and rc cars, i only use it on bikes, cars etc...
