Wierd question
I've always fancied a beetle buggy, but can't afford a Scorcher and
want something I can run hard without having to worry about expensive
crash damage.  I've got a runner Bearhawk chassis with a damaged
shell, which is similar in size to my scrap Grasshopper (just a bit
wider, maybe), and would make an excellent donor chassis for a beetle
project.
Is the grasshopper wheelbase similar to the Scorcher, or would it look totally daft under a beetle shell..?
If I use the Bearhawk, I'll also need to locate some good scale-looking
wheels that will accept hexes on the rear and 1150 bearings up
front...  Suggestions requested please [:D]
Ax
Hey OldBoyHotstuff, they look good!  What's the front wheel used
on the orange one?  I guess that wheel takes two standard 1150
bearings..?
I measured up the Bearhawk this morning - it's a tiny bit longer than
the Hopper, and marginally wider - but it will look OK with the right
shell.  I'll need to find some good-looking hex-drive rear wheels
for it, obviously...  Anybody know a wide rear that accepts an
off-road or scale tyre and matches the wheel on the orange
beetle?  ISTR one of the CC wheels looks a little like that, but
can't remember what it's from...
Also, any links and/or pics of good readily-available beetle shells?
TIA! [:D]
Ax, both my pseudo-Scorchers use the Parma VW body, #10340. I believe Kamtec does the same one in Lexan or ABS. The orange one uses wheels from the TA02 Pajero, the fronts narrowed, rears widened. All are hex drive, as the front suspension is M03 parts.
The Lexan bodies can be dressed up considerably by using a Blitzer or Monster Beetle nose. The orange Bug has had a Blitzer nose installed since that pic was taken, and it looks much better.
ive done this convertion twice and it looks very nice
have a look in my showroom for pics
but if you want a baja runner why not turn the bear hawk into a blitzer beetle (same chassis) buy some N-parts (body mounts) and a body along with wheels and tyres and front uprights
Pete
y'know...  I didn't think of that?  Of course the chassis is the same!!  Good idea!  The blitzer shell would fit straight-up with just the N-parts...  And of course some changes to get some decent wheels on there [:)]
Ok - body conversion first, then I'll worry about wheels & tyres...
And the Bearhawk with Blitzer parts! - Ignore the beat up body, I used to run it with Optima rear wheels and Wild one fronts, Optima gave a little more scale look, this has the suspension pumped up too, which doesn't help the handling! - Glenn
