http://www.tamiya.com/japan/products/58378..._ta05/index.htm
Google translation:
Most fast Ferrari where the circuit matches> The
special limited model which is released in 2005 as a circuit travelling
private car for the owner whom you call only 29 in the world and is
limited, is Ferrari FXX. As for the body panel which improves the
aerodynamics [entsuo] Ferrari as a base all carbon make. V type 12
cylinder engine of 6262cc which is loaded onto the midship starts
hitting 800 horsepower or more, e.g., the semi-automatic gear box which
is proud of the shift speed of 1/100 seconds is brought together group,
it is finished in the machine which was poured not to spare the Ferrari
F1 technology. Ferrari of this most speed is appearance by the
electromotive RC car. Reality reproducing the body which insists the
preponderant existence impression fully with polycarbonate. The rear
end which adopts the rear wing of left and right division type the 3-D
is the completion which overflows as another part of the resin make.
High efficiency isometric 2 belts 4WD, adoption TA05 chassis> As
for the chassis concentrating the know-how which is cultivated with
race/lace, the high efficiency which was developed adopting TA05 of 2
belts 4WD for just Ferrari FXX of the circuit travelling private car.
Approximately converting the drive belt isometrically, those which hold
down the flexion and blurring of the belt and pursue the drive
efficiency of the high-speed travelling time more are the largest
point. Furthermore, the motor in the central approaching of the left
side, loading the battery onto vertical ranging in right side,
optimizing resin make [rowadetsuki] which to center of gravity which
does not have the upper deck is converted low, weight balance. In
addition, the full bearing, fully loading the high functional part of
the front and back ball diff. and one somatotype motor mount etc. In
addition, each bulkhead e.g., it makes top and bottom block
construction, cannot overlook either the maintenance characteristic
which is superior. Combination of the advanced chassis and the force
body attracting attention even with the RC circuit is secure.
Guest joelvardy
hate to sound dumb but was there any question in this post or were you just giving us info?
Google translation:
Most fast Ferrari where the circuit matches> The special limited model which is released in 2005 as a circuit travelling private car for the owner whom you call only 29 in the world and is limited, is Ferrari FXX. As for the body panel which improves the aerodynamics [entsuo] Ferrari as a base all carbon make. V type 12 cylinder engine of 6262cc which is loaded onto the midship starts hitting 800 horsepower or more, e.g., the semi-automatic gear box which is proud of the shift speed of 1/100 seconds is brought together group, it is finished in the machine which was poured not to spare the Ferrari F1 technology. Ferrari of this most speed is appearance by the electromotive RC car. Reality reproducing the body which insists the preponderant existence impression fully with polycarbonate. The rear end which adopts the rear wing of left and right division type the 3-D is the completion which overflows as another part of the resin make.
High efficiency isometric 2 belts 4WD, adoption TA05 chassis> As for the chassis concentrating the know-how which is cultivated with race/lace, the high efficiency which was developed adopting TA05 of 2 belts 4WD for just Ferrari FXX of the circuit travelling private car. Approximately converting the drive belt isometrically, those which hold down the flexion and blurring of the belt and pursue the drive efficiency of the high-speed travelling time more are the largest point. Furthermore, the motor in the central approaching of the left side, loading the battery onto vertical ranging in right side, optimizing resin make [rowadetsuki] which to center of gravity which does not have the upper deck is converted low, weight balance. In addition, the full bearing, fully loading the high functional part of the front and back ball diff. and one somatotype motor mount etc. In addition, each bulkhead e.g., it makes top and bottom block construction, cannot overlook either the maintenance characteristic which is superior. Combination of the advanced chassis and the force body attracting attention even with the RC circuit is secure.
[;)]boo hoo give them a dummy google google google
Not lovin those wheels but the body looks tasty
Terry, those dual exhausts look cool.  looks like the wing could be hard plastic.
A note about the wheels on that car: from the Tamiya USA site it said the wheels had a +4 offset to them to fill the market for wider wheels and tires. Sounds like a rather niche market to me.
