what is the best suspention upgrade for the lunchbox other than the tamiya oil shocks. are there any alloy ones that fit well. You could recommend. Thanks
This is a toughy as the lunch box needs a 3 inch damper.  Most dampers out there are longer than this.  Also the duraleak 3" shocks are really only 63mm which makes them too short.  I use losi dampers on my pumpkin but I also run spacers on the inside to limit the length.
