Okay.  Would you fellas that have experience with these radios & have built them into your High Lifts be able to post some "How To Use/Set Up" a 4 Channel/6 Channel Radio ?  I have read that the same stick is used for throttle/steering, the other for shifting [:^)] ? Little help here - my biggest venture has been a 3 channel pistol so far.
Please post the radios you are using & the general set-ups if possible.  Thanks in advance fellas.
My Aeromax setup - Left stick is for 1st 2nd and 3rd gears fwd/rev that takes up 2 channels.(you may need to buy a shift gate if there is'nt one with your radio).....
Right stick is for steering and the up/dwn is horn and lights this is the same setup i'll be putting into my hi-lift.
HTH Steve.
