I cant help you with answer as to how, but why do you want to change it. Is there a specific reason.
Toe in on rear wheels settles makes the car much more stable, start removing it or even adding toe out will make for an unstable car. My recommendation is to leave as is.
What is your assessment of the actual toe in angle?
Is it possible it's been assembled wrongly? (front rods on rear and visa versa, for instance) I've done this a couple of times and ended up with some spectacular geometry!!!!
Is it possible for you to post a pic showing what you mean? maybe an overhead view?
GPZ1000RX the toe in is set on the blazing star, a combination of hub, wishbone and inner mounts etc. I would check that the rear hubs are fitted to the correct side, or even check that it has the correct hubs for the car.
