Wanted to start this already 3 weeks ago, but always was forgetting it, find it weird that noone else noticed it yet.
There is something very interesting / weird in the F350 kit, lets see if someone finds it out.
If not, will post it on Monday on my site / blog.
Won't help yet as its really something you would know its it when you see it, but if noone is close in a day or so, may give a hint.
Ok Theo, My first shot:
Concearning the Diffs: When you lock the diffs you should use a rubber thingy without the lock the manual doesn't show it.
Max
Max
Also with the rubber thingy the silver diff case doesn't fit (so manual is wrong?), good try [:)], but thats not it, what I am looking for is much more impressive/surprising.
Keep them coming! [Y]
Guest sk8te-penguin
is it that stupid shock spring that stopps almost all articulation?
or is it that they have light pods but give you stickers?
Im still working on completing mine, but  I did notice something is not right with the way the axles sit when configured with soft suspension. Like there is a tweek problem or something. I checked the assembly to be sure I put it together correctly and found nothing wrong there.
 Unless your refering to something odd with the actual contents of the kit, then Im way off base.
g
There is a few things in the kit I found that seemingly have no business being there.
On another note, there is a part on one of the trees that the manual states is for the MFU.
If Im still way off then I will have to review the left over parts bin when I get home this evening.
I have not seen a kit "in the flesh" yet - but knowing you Theo - if it had a blister pack you would just about jump out of your skin for "old times" sake ! [:P]
 That is a wild guewss I know - but hey !
Darryn
How about if this is a all new model then why is there a spare gear that's not used,spose someone is now going to tell me this has been covered somewhere else[:$]
Darryn
You sure know me well [H]  but unfortunately no blister (at least tires smell nicely rubberlike! [:D])
it wouldnt be the little picture of the nitro motor with  GP on it  on the bottom of the decal sheet would it?
And we already have a winner! Congratulations Barney [H][Y], yes, I meant the EP/GP written on the decal sheet!
So it seems there will be a nitro F350 in the future! [H] Now let the speculations begin! [:P]
I say a nice low revving 4 cycle nitro or even better diesel, not powering the gearbox directly, but a generator, gearbox is still driven by electric motor for low speed crawling and no need for clutch, coupled also with a new Hilux body, making a hybrid (synergy drive) RC like its 1:1 counterparts from Toyota/Lexus/Honda. Don't take it seriously, just wishfull thinking, but maybe in 10 years??
i had the wife searching the parts trees etc and i grabbed the decal sheet and the nitro motor was about the only really odd thing i could find.
with the 4 link mounts supplied, could that be a hint as to a 4 link version in the future maybe?
Yes, on the manual it writes they are for (future) hopups (scan from Shodogs showroom)
Guest sk8te-penguin
yey!!! a 4 link coil spring variant with a mercades G-Wagen body or even better....
RANGE ROVER CLASSIC 2door AND! 4door!!!
i really hope the above!
