I finally took my 2nd-hand Blackfoot Extreme out for the first time
yesterday - had it nearly a month, collecting dust and going
nowhere...  Handles very wheel for a stock 2wd truck with friction
shocks etc, but I was a little disappointed with the speed. My Dark
Impact aces it in just about every challenge - including some seriously
rutted and bouncy places.  The stock DI is so much faster than the
BEx that given enough run-up, it'll just bounce over any obstacles in
its path, whereas the slow old BEx doesn't have enough speed to get
across, and then gets bogged down and needs to rely on its (sadly
lacking) torque to pull itself out of the thick stuff...
That
said, it is very good at power-climbing - it faired better than the DI
up some steep, slippery, leaf-strewn slopes, despite being only
2wd.  Given some extra run-up speed and some additional climbing
torque, I bet it'll run over anything!
TIA [:D
You are right, the Blackfoot Extreme is really slow with stock motor and pinion. [:S] I use the new Tamiya Super Stock BZ
motor in my Mighty Bull (same chassis as Blackfoot Xtreme) with the 20T pinion and full ball bearings. Works perfect. Great torque and top speed.[:D]
I´ve installed the standard TEU101 ESC in my car and never had any problem with overheating.
Thanks for that advice - it was already fully ballraced when I got it, and came with an NIB silvercan but no speed controller.  I could swap the ECO27 for a TEU out of my Pumpkin and run a Super Stock BZ :)
