motocrosser 1 Posted November 7, 2006 Hi I need some help about the Kyosho Nitro Quad Rider: Does Tamiya 1:10 rims fit on the quad? Because I want to use this wheels. This is a Tamiya Carson 1:4 Elekric quad, and I think it uses Standard 1:10 Tamiya fitting. http://www.offroadmarkt.de/carson-x-quad.php Is there a manual online? Someone can help me to get one? Thanks, sorry for my english... Share this post Link to post Share on other sites
TWINSET 1394 Posted November 7, 2006 For rear wheels, it is ok, most 2.2 inch 12mm hex rims are good, but front wheels is not so easy - front shaft is 6mm dia and Tamiya wheels use 11mm OD bearings - and 6 x 11mm bearings are a bit hard to find. I changed rear wheels, but not fronts Share this post Link to post Share on other sites
rhenbelz 0 Posted November 7, 2006 I've got four brand new 6x11 bearings if you want them, they should let you fit 2.2 wheels. Share this post Link to post Share on other sites
motocrosser 1 Posted November 7, 2006 It will take one week till I get the Carson x-quad and the Kyosho one. Then I can have a look to the X-Quad wheels and know what I need, I will contact you, Thanks! But, how's about the manual, I know....it takes some minutes to scan... Share this post Link to post Share on other sites
TWINSET 1394 Posted November 7, 2006 AH Carson Quad is 4WD which means front wheels will have hex probably. That will make it harder to fit bearings at front. Share this post Link to post Share on other sites
rhenbelz 0 Posted November 7, 2006 If they have a hex you may need to adapt and install rolling hexes, perhaps get some from a (original) Traxxas Stampede or something like that? Share this post Link to post Share on other sites
