Hello All,
I'm new here (but I've been looking at the site regularly for two years) and have a few questions.
1. Will a Futaba R122JE receiver fit on the GB-01 chassis? Will it fit under the frog shell? Maybe someone who has a Mini-Frog could measure the receiver for me?
2. I also noticed the antenna tube holder sits above the receiver as a sort of clamp. Would this adjust up and down if you put in a larger receiver?
3. Does anyone know if Tamiya are likely to release a 40mhz version of their Tamtech Gear receiver?
4. Does anyone know of 40mhz 2 channel receivers that would be suitable for the GB-01 chassis?
5. Has anyone used Yeah Racing receivers? Are they any good? They look in the photos to be very small and set in plastic/resin? What does 50U mean? Would they work with a Futaba Attack 2ER 40mhz? Here are some links to the actual items:
http://www.rcmart.com/catalog/images/yrac_rx6-40_001.jpg
http://www.rcmart.com/catalog/product_info...oducts_id=20319
6. I don't want to paint my Mini-Frog the standard pink, so has anyone had a look at the decal sheet? I noticed that the 'Frog Racing Team' lettering is within a pink stripe which I intend to carefully cut out. Also the number 1 in the side of the wing is also on a white background, which I'm sure I could do the same with. Is the rest of the decal sheet also on coloured background rather than the standard clear?
7. Has anyone (who has access to the right equipment) thought of doing a scaled down version of the 1:10 decals (original NGK ones preferably)?
8. Does anyone know when the GB-01 chassis kit is going to be released?
Sorry to bombard you all with so much on my first post, but I've been looking for answers to these questions all over the place.
Thanks in advance for any info.[8-|]
I can only answer a couple of your questions.
1. The Futaba R122JE receiver will fit on the TTG Frog but I had to move the speed controler (TEU-102BK) forwards and the battery connector now only just fits through the acess hole.
2. The antenna holder is not adjustable.
6. The rest of the decal sheet appears to be printed on clear.
Hope that this helps.
