I have a soldering gun! [:D] Much easyer! It takes 35seconds from when you pull the trigger to heat upto soldering temp! and only cost me a masive £12 :P Included is flux, loads of solder and three extra nibs!
nice siv they are handy things to have [:D]
will get mine from local hardware store (got a tasty one ) sure the chap said they can be adjustble (heat output) [:P]
Paul
The reciever has BEC according to the label.
hmmm I'm beginning to think the esc itself is faulty. I soldered the capicitors on and the same thing happened. The motor works fine with the tamiya esc however. Im 99% certain the esc is getting the correct signal from the reciever because the lights are lighting green when I push forward, red for reverse and both when in nuetral which is what they are supposed to be. The manual/pamphlet says that when the motor kicks off before you can even set it up the unit could be faulty.
One word for that... ****** [V]
