I'm about to buy a TXT-1 and want to fit (IMHO) the more realistic Clod wheels to the TXT-1. Do the CB wheels mount to the TXT-1? Also, to ask another lame question, are the CB tyres the same size as the TXT-1's?
Thanks,
Mike
The tires are exactly the same for both models.
Do you mean you want to mount the original Clodbuster white rims to the txt-1 ?
Or do you want to mount the new Super Clodbuster Chrome rims ?
The rims are not interchangeable because the rim hub has a different set of holes. (I think).
So, you would have to buy a new parts tree.  I would just keep the txt-1 rims/tires they are basically the same thing except for the mounting holes.
what I found is that the hub holes for the TXT are larger than those for the clod.  If your putting clod wheels on a TXT , they will go on but the pins in the back will be loose in the holes of the TXT hubs.  your best bet it to buy a set of clod hubs.  In all honestly though, the TXT wheels look tons better than the clod.
  • 17 years later...
Hey I know this is old but I am knew to the clod buster scene and wanted to know if the chrome super clod  buster wheels will fit on the original clodbuster? Also will the test chrome wheels fit on the original clodbuster? Sorry for the newbie questions and thanks in advance
The chrome clod wheels and white wheels are the same wheel, just different colors.
A bit late, but if you want to fit clod wheels on a txt, you'll need the shorter clod stub axles as well as clod wheel hubs. Everything will bolt right on that way.
