Guys - I got my TA01 barings through but the smaller barings that should be 850's have too small an internal diameter to fit the gearbox shafts through them [:S] .
How does the numbering work on these barings?
If I can prove they sent the wrong size barings then I can send them back
Cheers in advance
1150 bearing means the outer diameter is 11 millimeter and the inner diameter is 5 millimeter
850: outer diameter 8 m, inner diameter 5 mm
1 mm  = 0.039 inch
 cheers
Michael
superb info there miga - I never knew that,
What about the depth of the bearing would that make 1150 + Z value for depth i.e. 30 for 3mm?
Cheers Ryck
yes the depth is the last number eg 1155 means 11 outer 5 inner 5 deep.
don't know why but with the Tamiya bearings and naming convention the depth is not declared anyway.
if you buy single bearings in some other store, you must always declare the depth of your bearing, too.
cheers
Michael
Thanks Michael - perfect info. I've written back to them to ask them to exchange them. I've used For Big Boys on e-bay many times with no problems, so hopefully it's just an oversight that they'll sort out. On measuring they've actually sent me 840 bearings based on the naming convention above (internal diameter is 4mm)
 Thanks again
Cheers Ryck
The letter designations used with bearings refer to the materials used. These are some of the ones that a bearing shop gave me.
  • Z - Steel
  • R - Nitrile Rubber (Acrylonitrile butadiene rubber)
  • D - Carboxylated Nitrile Rubber
  • P - Polyacrylate Nitrile Rubber
  • S - Silicone Rubber
  • V - Fluoro Rubber
  • T - Teflon (Polytetrafluoroethylene)
  • L - Leather
  • F - Felt
Different manufacturers and suppliers use different cominations of letters to designate if they are refering to to the seals or balls.  Usually if only one or two letters are used they refer to the seals.
Here's most of the more popular tamiya sizes;
Tamiya
Number _ O.D. ____ I.D. ____ Thickness
_620 ___ 6mm ____ 2mm
____ 2.5mm
_730 ___ 7mm ____ 3mm ____ 3mm
_830 ___ 8mm
____ 3mm ____ 3mm
_840 ___ 8mm ____ 4mm ____ 3mm
_850 ___ 8mm ____ 5mm
____ 2.5mm
1150 __ 11mm ____ 5mm ____ 4mm
1160 __ 11mm
____ 6mm ____ 4mm
1260 __ 12mm ____ 6mm ____ 4mm
1280 __ 12mm
____ 8mm ____ 3.5mm
1680 __ 16mm ____ 8mm ____ 5mm
2617 __
26mm ____ 17.5mm _ 5mm
1510 __ 15mm ____ 10mm ___ 4mm
