I couldn't wait to build this. My most enjoyable build so far, mainly because I scrounged all the bits seperately over a month, till I had them all in a big pile looking at me. It cost a fair bit, but meh.....its only money, innit?
This build didn't follow any instruction manual order, I only followed the Egress manual for the gearboxes, then followed the Carbon chassis manual, the sheet with the Hi caps, and the ballrace steering instructions, so its in a bit of a jumbled order compared to the Egress instructions.
A massive thanks to Antony (Europro) Myles (Vintageavante) Bob Price from Modelbuild, and Victor101's RC car shop on Ebay. Without you all I'd be a lot richer!![:P]
Anyway....lets shaddup and build this thing, eh?
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007112843_1.jpg
This, as you may have guessed, is a pic of nearly all the bits used for the build, minus a few odd screws that I had to scrounge from my other kit leftovers.
First up, the front diff, from the ball diff and torque splitter set. Parts used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007112843_2.jpg
First step complete.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007112843_3.jpg
Next the middle gear and balls in the diff:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007112843_4.jpg
Gear in place ready to bolt together:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007112843_5.jpg
First diff finished. These are a very nice little piece of engineering!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007112843_6.jpg
Now we'll do the rear diff:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007113313_1.jpg
Ready for middle gear.....
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007113313_2.jpg
The two diffs done.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007113313_3.jpg
Now we'll start on the rear gearbox:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007113313_4.jpg
Case together:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007113313_5.jpg
Case and the bits to fill it:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007113313_6.jpg
Shafts and bearings in and on:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114007_1.jpg
In the case they go.....
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114007_2.jpg
.....and we screw the lid shut!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114007_3.jpg
Next, the front case. Bits for the first step:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114007_4.jpg
First step done:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114007_5.jpg
Second step bits:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114007_6.jpg
Second step done.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114438_1.jpg
Now lets fill it with gears:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114438_2.jpg
Gears in, lid threatening to go on:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114438_3.jpg
Ah!! Here's the lid, and some other stuff:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114438_4.jpg
Front arm front mount together, along with a very nice alloy body mount!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114438_5.jpg
And the front gearbox is complete!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114438_6.jpg
More next post.
Now for some carbon. The lower chassis and spacers:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114857_1.jpg
Done:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114857_2.jpg
Now for the gearboxes:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114857_3.jpg
Gearboxes on!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114857_4.jpg
Centre drive gear: I chose the one-way option, rather than locked.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114857_5.jpg
Ready to install:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007114857_6.jpg
Might as well put this together and install it while I'm at it:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007115550_1.jpg
All gears installed:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007115550_2.jpg
The mighty Dynatech 02H!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007115550_3.jpg
Ready to go in:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007115550_4.jpg
....and in it goes! (along with the propshaft)
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007115550_5.jpg
Now for the upper chassis, parts used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007115550_6.jpg
Upper chassis installed:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120028_1.jpg
The rear swaybar assembly, parts used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120028_2.jpg
Swaybar assembled, ready to bolt on with rear bumper, etc.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120028_3.jpg
Done:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120028_4.jpg
Time for some rear arms:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120028_5.jpg
Ready to bolt on.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120028_6.jpg
Rear arms on, and swaybar connected:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120427_1.jpg
A very rare and expensive parts tree, which I promptly ripped to bits.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120427_2.jpg
Rear uprights, along with uni shafts:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120427_3.jpg
Rear uprights ready:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120427_4.jpg
Bits to complete the rear end:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120427_5.jpg
Upper arms together:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120427_6.jpg
Rear end done!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120839_1.jpg
Now for the front. Bits used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120839_2.jpg
Ready for mounting:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120839_3.jpg
Mounted:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120839_4.jpg
Front upright assembly, bits used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120839_5.jpg
Front uprights done, ready to bolt on:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007120839_6.jpg
Mounting front uprights. Bits used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121316_1.jpg
Front end done!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121316_2.jpg
Bumper and front swaybar next, parts used:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121316_3.jpg
Ready to mount:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121316_4.jpg
Mounted.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121316_5.jpg
Now the rear shock mount:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121316_6.jpg
Assembled, ready to install:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121733_1.jpg
Installed on chassis:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121733_2.jpg
The Avante Ballrace steering set!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121733_3.jpg
All ready to install:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121733_4.jpg
Installed:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121733_5.jpg
I had to use some Vanquish tie rods for now, proper ones on their way.
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007121733_6.jpg
Tie rods on:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122210_1.jpg
The battery retainer and antenna mount:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122210_2.jpg
Installed:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122210_3.jpg
Steering servo and bits (wrong rod pictured!)
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122210_4.jpg
Servo installed (with correct rod!)
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122210_5.jpg
Nearly there.....shocks and wheels to go.
I'll continue this tomorrow....Corpsey needs his Deathsleep!![;)]
Fantastic build thread Corpse Thrower. Its awesome to read and follow a build of a car that I don't know anything about. It looks like a serious bit of racing machinery. The rear suspension is interesting too and is slightly reminiscent to me at least of the Losi JRX2 5 link suspension, with this Tamiya version modified to 3 links.
Anyway I look forward to the conclusion to this thread. Oh great pics too btw.
Top stuff mate what a machne think i will have to keep my eyes open for a runner egress as i would love to give one of these a go.
Top stuff!  Awesome build.  That pile of parts made me drool[:P].  The Avante and Egress are simply beautiful pieces of machinery.
An excellent guide, reminds me of when i built my Egress some 16 years ago, and then when I rebuilt it last year after finding it in my parents garage.
You didn't include the pictures of dismantling the front uprights and rebuilding them the right way roundemotion-5.gif
Awww......you've just wrecked the competition that I was going to run......
"Guess what I did wrong. Winner gets this chassis"[:P]
You shoulda waited mate.........
OK, now for some shocks!!
The Hi cap short set used on the rear of this car:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122210_6.jpg
Now ready for oil:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122627_1.jpg
Shocks ready for mounting:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122627_3.jpg
I had to remove the wing stay to fit longer screws, supplied with the Hi cap set:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122627_2.jpg
And they're on:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122627_4.jpg
Hi Cap Mini set, the fibreglass shock mount is supplied with these:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122627_5.jpg
Ready for oil, you don't get any oil with the Hi caps, so I used oil from my Dynastorm kit:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007122627_6.jpg
Front shocks ready for mounting:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123040_1.jpg
First the shock mount goes on:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123040_2.jpg
....and we're done!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123040_3.jpg
Beau....
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123040_4.jpg
....ti.....
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123040_5.jpg
.....ful !!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123040_6.jpg
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123454_1.jpg
I'll mount my new Vanquish wheels and tyres till I get some black Egress wheels and hybrid spikes:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123454_2.jpg
Tyres on the rims:
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123454_3.jpg
And that is the end of the build. Tyres on, and its finished!!
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123454_4.jpg
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123454_5.jpg
http://www.tcphotos.com/getuserimage.asp?t=n&id=img14438_15012007123454_6.jpg
There you go!!
I hope you all liked what you saw. More pics in my showroom. This thread should give you a bit of an insight on what its like to build one of these spactacular cars....I certainly enjoyed the build, anyway!!
Now for the Vanquish!!
Cheerio (of Death)[:P]
  • 4 months later...
Very nice build mate, done a couple of them myself and i rate them highly except thos oh so breakable (as in nackered and break the bank) C parts!. TF Evo is also a nice build try one.
Well you just need to get some wheels, tyres and a bodyset and your done (and seeing as loads of the parts came from me i should give you a nudge and tell you i just listed most of what you need on ebay!. I will be listing body/wing/undercowl soon also!. Cheers
Don't ruin the chassis glueing the reinforcements. It's really not needed, believe me. I ran Vanquish with homemade carbon chassis, Avante 2001 and Egress and the parts were not glued. No problems found.
Max
Whack me an email mate, need wheels, a propshaft, and rear hybrid spikes. And a bodyset. I'll take the lot, might as well finish it, eh?
Great build and excellent photos!
10 points to anyone who can point out all the differences in this build compared to the original Egress?
There are 5 I can see:
It is EGress geek out time boys!
This should be interesting.
James.
James.
Differences found on Egress:
-sealed ball bearings throughout
-taller front shock tower
-front lower cantilever shock mounts
-front & rear gold springs
-turnbuckles on steering tie-rods
-titanium screws throughout
-aluminum nuts throughout
-black wheels
-hybrid spike tires
-no aluminum front body mount (for vanquish body-shell only)
-rear dog-bones (not universal shafts)
-no rear bumper on Egress (chassis under-tray rear-mount instead)
I think that's everything... :(
  • 17 years later...
