Hi,
I've just built my first Tamiya a Re-Re Grasshopper only completed it on Saturday morning and what fun it is[:D]
Now i'm wondering what i can do to it to upgrade it. How much faster will it be with a 540 motor? What else should I consider and what would the benefits be?
John.
Hi,
Glad you're enjoying the 'hopper!
A 540 motor is the
easiest way to get more speed from your grasshopper.  A basic
silvercan can be had for very little and will make a noticeable
difference to the acceleration.
You can also fit the rear shocks
from a Hornet, as I believe this are slightly different - although I
love my old Hopper even in standard trim.
Did you build the
'hopper with sealed metal bearings?  If not, fit those too - £10 -
£15 should get you a set from a good hobby store or Ebay.
Some
companies made suspension upgrades for the front-end, try looking in
the Vintage forum, although you might have trouble getting hold of new
parts for those.
I'm also still searching for oil-filled shocks for the hornet, haven't found them yet. I think they are very difficult to become.
And I can really recommend ball bearings or sealed ball bearing.
About the motor, you can buy a standard Mabuchi or Johnson 550 or 540 (I can recommend A johnson). And if you want to spend some more money on the motor you can buy a superstock BZ (by dinball), the TEU-101BK esc can have this motor. If you take the superstock you will go much faster then with a standard 550.
But be sure to buy ball bearings first if you want a faster motor in it.
Guest DImblum
Agreed. I had to do some decent searching on Ebay to find the vintage front and rear oil-filled shocks for my GrassHopper. I also had luck placing some want adds on TC. You would be surprised what some of the members have for sale. Most parts I bought were from members who don't often post in the forums or in their showrooms.
I have a few vintage items for sale if you are interested. Feel free to check my showroom for some of the parts I have found and/or can help you locate.
Hi there, a 540 motor will be much faster than a 380 kit supplied job. Just bought a hopper myself and replaced motor. you will also need the 18 tooth pinion gear for it to work (part number 3515006, about £3.00, hornet pinion gear, NOT 18T AV pinion gear from touring cars).
A few suggestions for you to think about!!
Hornet rear shocks are oil filled and higher performance (given the rigid rear axle of the grasshopper)
Full ball bearings are a must have before other hop-ups and are available quite cheaply now.
ESC to replace mechanical speed controller if that is what you were supplied with  (although I think the re- releases all have TEU type tamiya ESCs)
 you might consider another bodyshell or 2, perhaps a hornet lexan one, or the 'sand scorcher' type shells can be made to fit the Grasshopper for a budget sand scorcher look.
Rear spiked tyres, again from a hornet, will give differing performance than the 'paddle' kit supplied tyres, should give better grip on some surfaces.
A higher capacity NiMH battery or 2 to give longer run times.
dont think there are really that many hop ups for a grasshopper, certainly not compared to TT-01/ TL-01 type tourers etc...
hope that helped
Neil
