Hello,
Just almost finished building it, I have a problem.
On the front drivetrain, a piece is touching the tires.
Here's the shot :
In red, the piece that touches the tire (here, front left wheel)
In yellow, the fix for the direction bar (that comes from the servo). This bar can not be shortened as it is one piece plastic. I tried to revert it, change between right and left, any possible position, still the same problem.
In green, the piece on which the direction bar is fixed. The piece also touches the tire.
The problem is the same on both font right and left wheels (no problem on the rear drivetrain).
I did not mix front and rear wheels as they have different shapes.
Thanks for your help
Are you sure you used the correct knuckles? The kit comes with a pair for the stock TL-01 and a different pair for the TL-01B, as I recall. Check that you are using the correct ones.
Just had a closer look at the picture. You are using the wrong knuckles. The ones you have on there are designed to work with touring car wheels (stock TL-01). You need to install the TL-01B knuckles.
You got it !
As I directly installed a SportTuned, I didn't take care of these parts that were packed with it. And didn't notice those I installed looked different from the manual.
Thanks a lot, they fit much better now [H]
