Hi,
I know this question has probably been asked before but the search bar takes forever to find what you are looking for. What is the best thing for stripping paint off a shell if you have an unlimited budget or a low budget?
Let me know, Shane
Your right, this question has been answered countless times but the answer depends on the shell.  Lexan or hard plastic?
I agree with Hunterzero.  If the paint did it's job in the first place, it will have etched into the plastic and you will end up with a cloudy look to the lexan.
 What ever you do, don't use oven cleaner or acetone.  I have not had good luck with brake fluid either
mr. muscle wont harm the lexan at all, i used 5  half hour applications to remove enamel from a shell and it was fine. wont work on polycarb paint though as stated above.
neil
Be careful on what you recomend.  I have tried yellow cn easy off oven cleaner on lexan bodies and it will craze and then crack into a thousand pieces.  I would never recomend oven cleaner for lexan
Not recommending it, just stating that was the product used and it was fine for enamel paint. Shell still in use now and no crackig/ crazing at all. Maybe not all oven cleaners have the same agents in them!- If your in the business of stripping well cured paint from an old shell, you gotta expect the occasional disaster in my opinion!
