i know that the limit is 23t but is there a limit the other way, i have a touareg with a sport tuned motor and i have just ordered a couple 35t integy lathe motors one for my hilift and one for this.
Except Tamiya recommends that you dont use the teu 101 bk esc with the high lift. Its a heavy truck and once its rolling it can make an esc do strange things.
I'm using the stock motor in my highlift, but due to changing the pinion for a smaller one, i've had to install an mtroniks viper rv-11 esc - as the current produced by the motor whilst slowing from full throttle in 3rd gear made any lower spec esc mess up [:S]
Running a high lift with a 35 turn motor and the 101 bk might be ok, but imho, can't say for sure if it will work. [;)]
the teu101bk and lathe motor would be in my touareg as i already have a ai pro reverse esc for the high lift. so was woundering if that suit the xc chassis. plus will runnig the standard pinion in the hi lift with 2.2" wheels on.
