hi all,
just got my m-03 chassis with a esc, its a msonik2 sports rv, does anyone have any info on this esc?
what turn does it run? spec sheet n stats?
any help will be gratefull
thanks nic stnicholas2@msn.com
Not 100% sure on the Mtronics2, but if it's any help, the Mtronics3 Sport RV came in 2 flavours, the Max (which doesn't say anything on it apart from SportsRV) and the RV15. The Max will go to any turn, the RV15 is limited to 15 turn motors.
Both of them have the standard Mtronics setup routine (turn on with the setup button pressed, go full throttle and full reverse on the transmitter and the ESC is setup).
Hope that's of some help.
hi,
got it to work! at the moment its running standard silver can! thanks for the info that it could run down to 15, il have to try it on the 15t motor i have graupner dr speed 15t
thanks
