Mokei Kagaku 2706 Posted January 30, 2017 More for 2017: 42311 TRF419X WS Chassis Kit 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted February 2, 2017 2017: 47346 Neo Scorcher Blue Metallic (TT-02B Chassis) 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted March 16, 2017 58646 Konghead 6x6 (G6-01 Chassis) 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted April 3, 2017 47355 Dual Ridge Black Metallic (TT-02B Chassis) 58648 Mazda RX-7 (FD3S) Drift-Spec (TT-02D Chassis) 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted April 11, 2017 57902 XB Ferrari F12TdF (TT-02 Chassis) 58647 M-07 Concept Chassis Kit [Added] ???? Team Lotus F102B (F104W Chassis) (probably re-release of 84287, but item number yet unknown) EDIT 13.04.2018: re-released with original item number. ???? FF-03R Chassis Kit (probably re-release of 84288, but item number yet unknown) EDIT 13.04.2018: re-released with original item nuber ???? Mitsubishi Pajero (CR-01 Chassis) (item number yet unknown) EDIT 13.04.2018: still pending / cancelled? Share this post Link to post Share on other sites
pininfarina 1009 Posted June 9, 2017 Please add ITEM# 58647 RC M-07 Concept Chassis Kit - M-07 Electric RC car series No. 647 1/10 RC M – 07 CONCEPT CHASSIS KIT (58647) ★ Drive system is full bearing specification Oil-filled type gear differential, universal shaft, high torque servo saver etc. are standard equipment. ★ 225 mm, 239 mm, two types of wheel base can be selected. * Body, motor, tire, RC mechanism, battery etc. are not included in the kit. M-chassis. 1 Share this post Link to post Share on other sites
pininfarina 1009 Posted October 15, 2017 ITEM 47362 - PORSCHE TURBO RSR TYPE 934 -BLACK EDITION - 50TH YEARS OF TAMIYA AT SPIELWARENMESSE Commemorating 50 years of Tamiya at Spielwarenmesse.2017 marks our 50th consecutive year of attendance at the prestigious Spielwarenmesse. This exciting R/C model assembly kit is a special color variation version of the Porsche Turbo RSR Type 934 Jägermeister (Item 84431). This variant uses brand new gold color stickers designed to accentuate a black color scheme. It comes in a cardboard carry case that makes it easy to transport your creation after it is built. The TA-02SW exhibits a short-wheelbase and has a wide track to accommodate the scale form of the real Porsche sports car. It normally features a tub chassis with 4-wheel, fully independent suspension coupled with a rear ball differential and a front gear type differential. This special edition is fitted with a double deck FRP chassis for increased rigidity and a few Hop-Up Options. Specifications: 1/10 scale R/C model assembly kit. Length: 435mm, width: 202mm, height: 130mm. Polycarbonate body with separate side mirror and wing parts. Separate light cases are also included. Includes aluminum motor mount, hard propeller shaft, FRP damper stays, ball diff cup joint, and universal shafts. Brand new stickers with gold color designs. Includes LED light unit to light up headlights and taillights. The TA02SW chassis has a short (236mm) wheelbase and wide tread setup. FRP (Fiberglass Reinforced Plastic) chassis. FRP front and rear shock damper stays optimize the CVA oil damper-fitted 4-wheel double wishbone suspension. The stainless-steel propeller shaft is highly durable and offers efficient transmission of power, particularly in combination with the front and rear assembly universal shafts, which come with ball diff cup joints. Enclosed front and rear gear cases have built-in diff gears. The rear is fitted with a ball differential. Comes with 2-piece wheels, tires and inner sponges. The rear of the model uses wide wheels. Full ball bearings included. Includes 540 motor. Requires: 2-channel radio, ESC, Tamiya PS spray paint, 7.2volt battery with charger. #47362 – MSRP $334.00 World Wide Store Sales Date: October 20, 2017 1 Share this post Link to post Share on other sites
taffer 948 Posted December 25, 2017 @twinset please add 47361 Landfreeder black matte special thanks Share this post Link to post Share on other sites
TWINSET 1793 Posted December 30, 2017 @taffer - added Share this post Link to post Share on other sites
gpgp01 36 Posted April 13, 2018 Hi, I was writing a gallery post in showroom of TC, but a needed item list wasn't shown so I couldn't finish. The item is 47367 Manta Ray (2018). Can it be made soon? Thanks. Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted May 30, 2018 2018: 47374 Ferrari 312T3 (F104W chassis) 58657 Land Rover Defender 90 (CC-01 Chassis) Share this post Link to post Share on other sites
pininfarina 1009 Posted September 28, 2018 Just collected mine ITEM 93044 - Hyundai i20 Coupe WRC. Ltd. Ed. TT-02 Share this post Link to post Share on other sites
pininfarina 1009 Posted October 12, 2018 http://www.tamiya.co.kr/mall/item.asp?siteid=tamiya&itemid=9457 model number 93044 model name Hyundai i20 Coupe WRC Kit TT 02 (ltd. ed) released Sep 2018 category TT 02 Chassis drive 4WD (Four Wheel Drive) suspension fully independent double wishbone chassis Bathtub Chassis i20 body included motor included width 192mm length 418mm wheel base 257mm gear ratio 8.27:1 scale 1:10 Releas price : 179,400 won •The complex 2-level rear wing is recreated using separate top and bottom sections for a realistic finish •Wheel hubs are designed to look like brake discs for a realistic and stylish appearance •Motor cover includes removable cooling duct •A case is included to keep the all-important receiver protected from dust and dirt •4-wheel double wishbone suspension utilizes friction dampers for a controllable ride. •Resin ball links in the steering linkage joints make for smooth, comfortable motion. •Molded 4-bevel differential gears ensure that the model offers smooth drive and cornering. •Gearbox cover can be removed simply with the loosening of screws on the frame. •51000 Hi-Torque Servo Saver (Black) •50746 CVA Super Mini Shock Units 2017 WRC i20 decals 1 Share this post Link to post Share on other sites
rjg1973 159 Posted November 15, 2018 Hello, Could you please add 47372 to the database? http://www.tamiya.com/english/products/47372/index.htm Thanks, Rob Share this post Link to post Share on other sites
rjg1973 159 Posted November 15, 2018 8 hours ago, TWINSET said: 47372 Added Thanks! Will add my new build shortly. Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted November 27, 2018 Items I couldn't find when specifically searching for each item. Hope I didn't miss any already entered models when I searched! 2017: 42315 TB Evo. 7 Chassis Kit 42316 TRF419XR Chassis Kit 47359 Tyrrell P34 Six Wheeler 1976 Japan GP Special Edition, F103RS 47364 TT-02 White Special Chassis Kit 56040 U.S. Main Battle Tank M1A2 Abrams Full-Option Complete Kit 56041 U.S. Main Battle Tank M1A2 Abrams Full-Option Kit 56351 Mercedes-Benz Arocs 3363 6x4 ClassicSpace Full Operation Kit 56353 Mercedes-Benz Actros 3363 6x4 Gigaspace Pearl Blue Edition Full Operation Kit 56354 Mercedes-Benz Actros 3363 6x4 Gigaspace Pearl Blue Edition 56604 1/25 British Battle Tank Centurion Mk. III (w/Control Unit) 57902 XB Ferrari F12TdF, TT-02 2018: 42318 TRF103 Chassis Kit 42326 TA07 MS Chassis Kit 47366 Plasma Edge II Black Metallic, TT-02B 47370 Isuzu Mu Type X, CC-01 47371 Neo Fighter Buggy / Neo Mighty Frog Green Metallic, DT-03 47375 Mitsubishi Pajero Metal Top Wide Black Metallic, CC-01 47376 King Yellow 6x6 (Painted Body), G6-01 47379 ProMarkt-Zakspeed AMG Mercedes C-Class, TT-01E 47381 Super Astute (2018) 47382 TT-02RR Chassis Kit 47383 Isuzu Mu Type X Black Metallic, CC-01 47384 1/8 Dancing Rider (Factory Finished Full Set) (Metallic Blue Body), T3-01 47385 1/8 Dancing Rider (Factory Finished Full Set) (Yellow Body), T3-01 47390 Avante (2011) Black Special 48214 1/35 WWI British Tank Mk.IV Male (w/2.4GHz Control Unit) 48215 1/35 Japan Ground Self Defense Force Type 10 Tank (w/2.4GHz Control Unit) 56355 Grand Hauler Matte Black Edition Full Operation Kit 56356 Grand Hauler Matte Black Edition 56357 Mercedes-Benz Arocs 3348 Tipper Truck 56605 1/25 German Tank Panther Ausf. A (w/Control Unit) 57406 1/8 Dancing Rider (Factory Finished Full Set), T3-01 57903 XB Toyota Gazoo Racing WRT / Yaris WRC, TT-02 57904 XB Team Hahn Racing MAN TGS, TT-01E 57905 XB Konghead 6x6, G6-01 57906 XB King Yellow 6x6, G6-01 57907 XB Subaru WRX STI NBR Challenge, TT-02 57908 XB Comical Grasshopper, WR-02CB 57987 First Try R/C Kit TT-02B Chassis w/Neo Scorcher Body 58656 Mercedes-Benz 190E Debis Team Zakspeed, TT-01E 84433 TA07R Chassis Kit 92395 XB Subaru WRX STI NBR Challenge, TT-02 93043 XB Hyundai i20 Coupé WRC, TT-02 2018/2019: 56358 Mercedes-Benz Arocs 3363 6×4 Light Gun Metal Edition Full Operation Kit 56359 Mercedes-Benz Arocs 3363 6×4 Light Gun Metal Edition 57407 1/8 Dual Rider, T3-01 58665 Toyota Gazoo Racing TS050 Hybrid, F103GT 84435 DT-03 Black Edition Chassis & Racing Fighter Body, DT-03 Share this post Link to post Share on other sites
acprc 1443 Posted December 2, 2018 42005 Tamiya OPS 3.5cc Pro Engine 1 Share this post Link to post Share on other sites
TWINSET 1793 Posted December 10, 2018 All added - cheers @Mokei Kagaku and @acprc On 11/27/2018 at 8:56 AM, Mokei Kagaku said: Items I couldn't find when specifically searching for each item. Hope I didn't miss any already entered models when I searched On 12/2/2018 at 5:43 PM, acprc said: 42005 Tamiya OPS 3.5cc Pro Engine 2 Share this post Link to post Share on other sites
acprc 1443 Posted December 31, 2018 Can you add a new chassis type please? TG10-Mk.2FN Thanks Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted January 11, 2019 2018: 92411 The Hornet Supreme 2019: 47394 Toyota 4x4 Pick-Up Mountain Rider 84436 M07-R Chassis Kit 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted January 21, 2019 2019: 47392 Tyrrell P34 1977 Monaco Special Edition (Painted Body) (F103RS) 47397 HKS Skyline GT-R (TT-01E) 47402 Lunchbox Red Edition (CW-01) 56042 1/16 U.S. Airborne Tank M551 Sheridan Full-Option Complete Kit 56043 1/16 U.S. Airborne Tank M551 Sheridan Full-Option Kit 58664 Ford Mustang GT4 (TT-02) 58666 Comical Hornet (WR-02CB) 58668 VW Type 2 (T1) (M-06L) 58670 Citroen 2CV Rally (M-05Ra) 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted January 30, 2019 2019: 58667 Audi quattro Rallye A2 (TT-02) 58669 M-08 Chassis Kit 56360 Volvo FH16 Globetrotter 750 6×4 Timber 1 1 Share this post Link to post Share on other sites
Mokei Kagaku 2706 Posted March 10, 2019 2018: 23802 1/14 RC Mercedes-Benz Arocs 3363 6x4 ClassicSpace (Full Operation Finished Model) (Red) (Yes, "ClassicSpace" is the correct spelling with capital S and no spacing) 23804 1/16 RC U.S. Main Battle Tank M1A2 Abrams (Full Operation Finished Model) 2019: 57909 XB Comical Hornet (WR-02CB) 1 Share this post Link to post Share on other sites
