57902 XB Ferrari F12TdF (TT-02 Chassis)
58647 M-07 Concept Chassis Kit [Added]
???? Team Lotus F102B (F104W Chassis) (probably re-release of 84287, but item number yet unknown) EDIT 13.04.2018: re-released with original item number.
???? FF-03R Chassis Kit (probably re-release of 84288, but item number yet unknown) EDIT 13.04.2018: re-released with original item nuber
???? Mitsubishi Pajero (CR-01 Chassis) (item number yet unknown) EDIT 13.04.2018: still pending / cancelled?
Please add ITEM# 58647
RC M-07 Concept Chassis Kit - M-07
Electric RC car series No. 647 1/10 RC M – 07 CONCEPT CHASSIS KIT (58647)
★ Drive system is full bearing specification Oil-filled type gear differential, universal shaft, high torque servo saver etc. are standard equipment.
★ 225 mm, 239 mm, two types of wheel base can be selected. * Body, motor, tire, RC mechanism, battery etc. are not included in the kit.
M-chassis.
  • 4 months later...
ITEM 47362 - PORSCHE TURBO RSR TYPE 934 -BLACK EDITION - 50TH YEARS OF TAMIYA AT SPIELWARENMESSE
Commemorating 50 years of Tamiya at Spielwarenmesse.
2017 marks our 50th consecutive year of attendance at the prestigious Spielwarenmesse.
This exciting R/C model assembly kit is a special color variation version of the Porsche Turbo RSR Type 934 Jägermeister (Item 84431). This variant uses brand new gold color stickers designed to accentuate a black color scheme. It comes in a cardboard carry case that makes it easy to transport your creation after it is built.
The TA-02SW exhibits a short-wheelbase and has a wide track to accommodate the scale form of the real Porsche sports car. It normally features a tub chassis with 4-wheel, fully independent suspension coupled with a rear ball differential and a front gear type differential. This special edition is fitted with a double deck FRP chassis for increased rigidity and a few Hop-Up Options.
Specifications:
  • 1/10 scale R/C model assembly kit. Length: 435mm, width: 202mm, height: 130mm.
  • Polycarbonate body with separate side mirror and wing parts. Separate light cases are also included.
  • Includes aluminum motor mount, hard propeller shaft, FRP damper stays, ball diff cup joint, and universal shafts.
  • Brand new stickers with gold color designs.
  • Includes LED light unit to light up headlights and taillights.
  • The TA02SW chassis has a short (236mm) wheelbase and wide tread setup.
  • FRP (Fiberglass Reinforced Plastic) chassis.
  • FRP front and rear shock damper stays optimize the CVA oil damper-fitted 4-wheel double wishbone suspension.
  • The stainless-steel propeller shaft is highly durable and offers efficient transmission of power, particularly in combination with the front and rear assembly universal shafts, which come with ball diff cup joints.
  • Enclosed front and rear gear cases have built-in diff gears. The rear is fitted with a ball differential.
  • Comes with 2-piece wheels, tires and inner sponges. The rear of the model uses wide wheels.
  • Full ball bearings included.
  • Includes 540 motor.
  • Requires: 2-channel radio, ESC, Tamiya PS spray paint, 7.2volt battery with charger.
#47362 – MSRP $334.00
World Wide Store Sales Date: October 20, 2017
  • 2 months later...
  • 3 months later...
Hi,
I was writing a gallery post in showroom of TC, but a needed item list wasn't shown so I couldn't finish.
The item is 47367 Manta Ray (2018).
Can it be made soon? Thanks.
  • 3 months later...
http://www.tamiya.co.kr/mall/item.asp?siteid=tamiya&itemid=9457
model number 93044
model name Hyundai i20 Coupe WRC Kit TT 02 (ltd. ed)
released Sep 2018
category TT 02 Chassis
drive 4WD  (Four Wheel Drive)
suspension fully independent double wishbone
chassis Bathtub  Chassis
i20 body included
motor included
width 192mm
length 418mm
wheel base 257mm
gear ratio 8.27:1
scale 1:10
Releas price : 179,400 won
•The complex 2-level rear wing is recreated using separate top and bottom sections for a realistic finish
•Wheel hubs are designed to look like brake discs for a realistic and stylish appearance
•Motor cover includes removable cooling duct
•A case is included to keep the all-important receiver protected from dust and dirt
•4-wheel double wishbone suspension utilizes friction dampers for a controllable ride.
•Resin ball links in the steering linkage joints make for smooth, comfortable motion.
•Molded 4-bevel differential gears ensure that the model offers smooth drive and cornering.
•Gearbox cover can be removed simply with the loosening of screws on the frame.
•51000 Hi-Torque Servo Saver (Black)
•50746 CVA Super Mini Shock Units
2017 WRC i20 decals
Items I couldn't find when specifically searching for each item. Hope I didn't miss any already entered models when I searched!
2017:
42315 TB Evo. 7 Chassis Kit
42316 TRF419XR Chassis Kit
47359 Tyrrell P34 Six Wheeler 1976 Japan GP Special Edition, F103RS
47364 TT-02 White Special Chassis Kit
56040 U.S. Main Battle Tank M1A2 Abrams Full-Option Complete Kit
56041 U.S. Main Battle Tank M1A2 Abrams Full-Option Kit
56351 Mercedes-Benz Arocs 3363 6x4 ClassicSpace Full Operation Kit
56353 Mercedes-Benz Actros 3363 6x4 Gigaspace Pearl Blue Edition Full Operation Kit
56354 Mercedes-Benz Actros 3363 6x4 Gigaspace Pearl Blue Edition
56604 1/25 British Battle Tank Centurion Mk. III (w/Control Unit)
57902 XB Ferrari F12TdF, TT-02
2018:
42318 TRF103 Chassis Kit
42326 TA07 MS Chassis Kit
47366 Plasma Edge II Black Metallic, TT-02B
47370 Isuzu Mu Type X, CC-01
47371 Neo Fighter Buggy / Neo Mighty Frog Green Metallic, DT-03
47375 Mitsubishi Pajero Metal Top Wide Black Metallic, CC-01
47376 King Yellow 6x6 (Painted Body), G6-01
47379 ProMarkt-Zakspeed AMG Mercedes C-Class, TT-01E
47381 Super Astute (2018)
47382 TT-02RR Chassis Kit
47383 Isuzu Mu Type X Black Metallic, CC-01
47384 1/8 Dancing Rider (Factory Finished Full Set) (Metallic Blue Body), T3-01
47385 1/8 Dancing Rider (Factory Finished Full Set) (Yellow Body), T3-01
47390 Avante (2011) Black Special
48214 1/35 WWI British Tank Mk.IV Male (w/2.4GHz Control Unit)
48215 1/35 Japan Ground Self Defense Force Type 10 Tank (w/2.4GHz Control Unit)
56355 Grand Hauler Matte Black Edition Full Operation Kit
56356 Grand Hauler Matte Black Edition
56357 Mercedes-Benz Arocs 3348 Tipper Truck
56605 1/25 German Tank Panther Ausf. A (w/Control Unit)
57406 1/8 Dancing Rider (Factory Finished Full Set), T3-01
57903 XB Toyota Gazoo Racing  WRT / Yaris WRC, TT-02
57904 XB Team Hahn Racing MAN TGS, TT-01E
57905 XB Konghead 6x6, G6-01
57906 XB King Yellow 6x6, G6-01
57907 XB Subaru WRX STI NBR Challenge, TT-02
57908 XB Comical Grasshopper, WR-02CB
57987 First Try R/C Kit TT-02B Chassis w/Neo Scorcher Body
58656 Mercedes-Benz 190E Debis Team Zakspeed, TT-01E
84433 TA07R Chassis Kit
92395 XB Subaru WRX STI NBR Challenge, TT-02
93043 XB Hyundai i20 Coupé WRC, TT-02
2018/2019:
56358 Mercedes-Benz Arocs 3363 6×4 Light Gun Metal Edition Full Operation Kit
56359 Mercedes-Benz Arocs 3363 6×4 Light Gun Metal Edition
57407 1/8 Dual Rider, T3-01
58665 Toyota Gazoo Racing TS050 Hybrid, F103GT
84435 DT-03 Black Edition Chassis & Racing Fighter Body, DT-03
All added - cheers @Mokei Kagaku and @acprc B)
On 12/2/2018 at 5:43 PM, acprc said:
42005 Tamiya OPS 3.5cc Pro Engine
  • Thanks 2
47392 Tyrrell P34 1977 Monaco Special Edition (Painted Body) (F103RS)
47397 HKS Skyline GT-R (TT-01E)
47402 Lunchbox Red Edition (CW-01)
56042 1/16 U.S. Airborne Tank M551 Sheridan Full-Option Complete Kit
56043 1/16 U.S. Airborne Tank M551 Sheridan Full-Option Kit
58664 Ford Mustang GT4 (TT-02)
58666 Comical Hornet (WR-02CB)
58668 VW Type 2 (T1) (M-06L)
58670 Citroen 2CV Rally (M-05Ra)
23802 1/14 RC Mercedes-Benz Arocs 3363 6x4 ClassicSpace (Full Operation Finished Model) (Red)  (Yes, "ClassicSpace" is the correct spelling with capital S and no spacing)
23804 1/16 RC U.S. Main Battle Tank M1A2 Abrams (Full Operation Finished Model)
2019:
57909 XB Comical Hornet (WR-02CB)
