got a keen hawk, have fitted acoms 40mhz radio, 10t limit esc, 13t yokomo pro stock 2 motor, standard pinion, alloy oil shocks, heat bars, slipper clutch, centre one way diff. rest of kit is standard with aditional 850 bearing for steering, was woundering about the gearing, have seen some 25,27t pinion gears for the df03 and was thinking more speeeeeeeeeeeeeeeeeed, what would you suggest.
Hi,
the gear ratio is wrong. You will cook the motor and the esc. You will need a smaller pinion gear and a bigger spur gear. The other mods seems ok.
Max
