Does anybody know if it's possible to find replacement tubes - the flexible parts - for the dampers?
The vinyl tubing can be picked up at your hardware store - usually sold by the foot - 0.025 inch outer diameter tubing.
PVC tubing... thought they were just "airline" for aquariums.
Don't use silicone fuel tube if you're using oil-based shock fluid, silicone will swell & fall off (big mess).
But if you're filling with a silicone fluid then nitro's fuel-tube will work ok.
(Dubro even sells little clamp clips for fuel lines...)
According to the 959/Celica user manual, the damper tubing is vinyl.
Oil-based shock fluid would not work very well (from my recollection) for RC - viscosity would change with temperature and would most likely gunk up.
