tI need some help , are the parts for the TA03 interchangeable with the parts for the TA03f pro?the reason is I've been seeing some parts for the TA03 at ebay but don,t know if they will fit my 03f pro especially when it comes to the motor part(eg.heat sink,gears) and what aout for the one way shaft and other parts for the diff's especially those oneway's,torque splitter and others.its a good thing theres such a wonderful clu like this that you actually ask questions and get the right answers or opinions.especially this item its called a tech racing super counter shaft for the TA03,will this work for my 03f pro?
tnx and more power to the clu.
All parta are interchangable, But the 03F PRO gears are 0.4 module and the standard 03F are 0.6 module, soa different pinion gear would be needed if you used the white gears as the 0.6 won't mesh properly with the 0.4 gears and will eventually put strain on the motor, and blwow the motor and strip the gears. But everything else can be used. [:)]
James
