The Ripmax Pro-peak will charge any capacity battery, even 4600s, but there is a built in cut off timer set at 1 hour as a safety feature. This means if you are charging a completely flat battery the timer will cut off at around 3000mah if you are charging from the mains and at 5000mah if you are charging from 12v. To top up larger capacity packs just start the charger again and it will cut off when it is fully charged.
thanks alot terry.
regards mark
