What is best is to not bother with the 380 motors since most Tamiya kits that use the 380 can either easily or with minimal parts be converted to 540 motors.
If you must run a 380 Tower Hobbies still stocks them with re-installed pinion gear. Also remember finding pinion gears to fit the smaller shaft of the 380/400 sized motors will be real fun. [Not!]
[8)]
quote:Also remember finding pinion gears to fit the smaller shaft of the 380/400 sized motors will be real fun. [Not!]
id="quote">id="quote">
Except if you have the magic little tubes given with the HB and SR [;)][8D]
Was wondering because I have a Tiger. Can't fit 540's
Would like to slow it down. No reply from guy who makes gear reductions. [:(!]
Wondering at what voltage Mtroniks was rated. [?]
