Not that drifting's ma thang but I was gonna get a set of 'Drifting' wheels off of eBay, they're basically just the plastic wheel but its been moulded round so you don't need tyres......should be good for a laugh....
ok thnx thats a start but what do i need to do than with my tires i heard PVC or ABS but how do they mean that ??
thnx for replying me
They are both pipe materials...
PVC is usually waxier & gives less grip.
ABS feels harder but gives a little bit more grip than PVC.
... either will reduce your grip so that you can go sideways with minimum of motor power,
so even a 540 or Sport Tuned is good enough.
Can buy & cut the pipe yourself or buy them ready-machined to fit your wheels.
A lot easier to buy ABS nicely machined with rounded edges...
If you're running Tamiya's Type-D tyres or the other commercially-made drift tyres
they are grippier and need a lot more power to start dancing. Plus they cost more.
(I feel the brushless SS5800 Novak is perfect for Type-Ds, different driving technique too)
TT01 is a solid car which handles drift-duty well, they're unkillable.
You should lock the rear diff (remove & dismantle diff, replace grease inside diff with glue/blutac/silicone).
I've got current car with locked diffs front & rear... need a bit more power if you lock the front diff too.
Oil shocks are a good option to stop the bouncing; i've put the alloy centre shaft too (hot motor).
Just about to get into building a TT01D ... probably be alloy shaft & heatsink mount on this one.
Adjustable suspension arms are moot, oil shocks as standard on TT01D... they drive better than they look.
My usual drift ride is TB02 & EvoIIIs... basically just bolt ABS onto my usual race rides.
With enough power EVERYTHING can be drifted - most of them run brushless motors.
Just question about where you are from? Im guessing Germany becuse you said something about Carson parts. I know alot of RC Drifters in Germany that might be able to help you if you need.They post on a forum in German and English. They drift the TT-01 and The Yokomo Drift Package chassis. They have alot of experience.
no in Holland
HI!
did you but the pvc? B)
I have a nissan Silvia Coppermix and it's really nice to drift with this car! it is a tt-01d, expert build.
If you need some info, I'm ready to answer!
I bought a long pipe of pvc (used by electricians for the illumination n gardens) and then, cutting, you obtain the tyres!
good job!!!!
HI!
did you but the pvc? :)
good job!!!!
jeah tnx maybe you could help me a bit
thnx
