Badcrumble 4203 Posted July 29, 2020 Events have conspired against me (phone packed up and I've had to re-arrange coming in to the office later this week) so I've had to rush my competition entry even more than usual! So not post-production editing as I'd hoped... https://www.tamiyaclub.com/showroom_model.asp?x=3675&vb=t&cid=135960&id=45667 It was fun to make though! 1 Share this post Link to post Share on other sites
•Axle 145 Posted July 29, 2020 Took my daughter and the GF01 to the park today, it’s hugely satisfying having the play taken out of the steering, feels like a different kit now with it going in a straight line and smaller steering movements being recognised. 2 Share this post Link to post Share on other sites
DeadMeat666 1675 Posted July 29, 2020 Installed the HW Quickrun BL120 esc and 4000kv 8.5 turn motor combo in the TT02S just now. I'm rethinking my perception of reality because of it. Here it is with the decidedly normal Tamiya sport tuned 'test' setup: And here it is with the demon-spawn combo installed and done: And HERE it is after I'd run it in my living room at VERRRY low speed just to make sure it's making all the right noises, and that nothing seems off (nothing seemed off). And then, just for ****s and giggles, I held it in my hand and mashed the throttle for a SPLIT second. This is what happened: Basically 3 tires instantly dislocated from the wheels, and the 4th was launched across the living room so fast that I couldn't tell where the it went. I looked around for a few minutes before I found the stray tire in the furthest corner of the room under a table. Note to self: GLUE THE TIRES BEFORE DOING SOMETHING STUPID LIKE THIS AGAIN. 6 2 Share this post Link to post Share on other sites
Lee76 638 Posted July 30, 2020 Started the laborious but enjoyably therapeutic job of customised Sand Scorcher body work. 6 Share this post Link to post Share on other sites
bozatron 96 Posted July 30, 2020 Braved the heat, it's been hitting 45*C and 55% humidity this week, and took the Blitzer for a bash ... 12 Share this post Link to post Share on other sites
yogi-bear 2321 Posted July 30, 2020 spent the last two weeks machining 4 more rims for my LandFreeder. The fifth and first one I did, will be the spare. Next I'll try machining a set of wheel hubs. I still have the machine a lip or edge at the back of the rim as its rubs against the hub if I tighten the wheel nut too much 13 2 Share this post Link to post Share on other sites
J@mes 2326 Posted July 30, 2020 17 hours ago, •Axle said: Took my daughter and the GF01 to the park today, it’s hugely satisfying having the play taken out of the steering, feels like a different kit now with it going in a straight line and smaller steering movements being recognised. Do you have a build thread? Interested to see what you’ve done 👍🏽 1 Share this post Link to post Share on other sites
Re-Bugged 10147 Posted July 30, 2020 Those wheels look bang on with the orange truck body @yogi-bear 👍🏻 3 Share this post Link to post Share on other sites
ploots 185 Posted July 30, 2020 1 hour ago, yogi-bear said: spent the last two weeks machining 4 more rims for my LandFreeder. The fifth and first one I did, will be the spare. Next I'll try machining a set of wheel hubs. I still have the machine a lip or edge at the back of the rim as its rubs against the hub if I tighten the wheel nut too much Looks good what colour is that 👍 Share this post Link to post Share on other sites
Lee76 638 Posted July 30, 2020 2 hours ago, bozatron said: Braved the heat, it's been hitting 45*C and 55% humidity this week, and took the Blitzer for a bash ... That terrain looks epic! Must be a blast to run on. Share this post Link to post Share on other sites
Badcrumble 4203 Posted July 30, 2020 Now I have the (painted) body for the M05-RA, it is time to get back on with the build. Took advantage of a sunny day and no family in attendance over lunch to paint the chassis guards. I started off with a used can of silver. Oops! Glad it will go under the body and not be too visible! 2 Share this post Link to post Share on other sites
•Axle 145 Posted July 30, 2020 2 hours ago, J@mes said: Do you have a build thread? Interested to see what you’ve done 👍🏽 I would like to do that, I think this build I’m classing as maybe a reintroducing to the hobby and this next one I have planned will be the one I take some photos of, it’s the silly things that go on them that have had me annoyed at times, after much thought I’m also going to buy a motor over 4000kv for more top end speed, It’s funny how much of a short acceleration range these brushless systems have, the 3300kv seems brilliant at sharp bursts of energy and hill climbing. Share this post Link to post Share on other sites
DarkSonic 212 Posted July 30, 2020 Shaved some weight from the original Top Force Diff on the lathe. Saved 3,3gr (from 11,9 to 8,6gr). Could be done a bit more, but want to keep some safety margin. 6 Share this post Link to post Share on other sites
Novamadcars 230 Posted July 30, 2020 Currently sitting here looking at my Built unused m03 mini debating to sell it or not 🤔 Share this post Link to post Share on other sites
Juhunio 6830 Posted July 30, 2020 Finished my first drifter...a TT02R bought as a deal from Tamico, with a rear diff lock and added Yeah Racing steering, battery posts and suspension mounts, a Fastrax carbon battery stay and Tamiya Drift Spec wheels and tyres. First run with the Rolson tube cutter wasn't great, so saved the other 3 body posts for another day. The ready-painted Datsun 240 body, with light kit installed, came from Seidel with help from @Mokei Kagaku and it's gorgeous (even if I did have to cut a new antenna hole); thanks man! Even on a test run around the small garage, this is a LOT of fun, recreating some Baby Driver moves . Out for a proper test tomorrow 8 Share this post Link to post Share on other sites
Wez-li 1790 Posted July 30, 2020 23 minutes ago, Juhunio said: Finished my first drifter...a TT02R bought as a deal from Tamico, with a rear diff lock and added Yeah Racing steering, battery posts and suspension mounts, a Fastrax carbon battery stay and Tamiya Drift Spec wheels and tyres. First run with the Rolson tube cutter wasn't great, so saved the other 3 body posts for another day. The ready-painted Datsun 240 body, with light kit installed, came from Seidel with help from @Mokei Kagaku and it's gorgeous (even if I did have to cut a new antenna hole); thanks man! Even on a test run around the small garage, this is a LOT of fun, recreating some Baby Driver moves . Out for a proper test tomorrow Love that 240z I've got a TT02 on the way, can't decide on a body yet though. I fancy an old school skyline. 1 Share this post Link to post Share on other sites
Wez-li 1790 Posted July 30, 2020 Got the M03 project car ready. This is the last of the 4 m-chassis haul to be stripped, cleaned and rebuilt. 2 Share this post Link to post Share on other sites
yogi-bear 2321 Posted July 30, 2020 7 hours ago, ploots said: Looks good what colour is that 👍 that would be Tamiya's PS-61, metallic orange Share this post Link to post Share on other sites
ChrisRx718 4470 Posted July 30, 2020 Stuck the MST rims on my "accidental purchase" Wrangler Looks the part now. Not really sure what direction to go with it, but found this "Islander" spec Jeep online and love it: Problem is I can't find the side / bonnet graphics anywhere, does anyone have any pointers? 2 Share this post Link to post Share on other sites
Finnsllc 917 Posted July 30, 2020 7 hours ago, Badcrumble said: Now I have the (painted) body for the M05-RA, it is time to get back on with the build. Took advantage of a sunny day and no family in attendance over lunch to paint the chassis guards. I started off with a used can of silver. Oops! Glad it will go under the body and not be too visible! those were not fun to cut out on mine Share this post Link to post Share on other sites
Bash 356 Posted July 30, 2020 Picked up a new charger and a Losi Mini-T 2.0 from the hobby shop 2 Share this post Link to post Share on other sites
Badcrumble 4203 Posted July 30, 2020 32 minutes ago, Finnsllc said: those were not fun to cut out on mine No, not fun. I took off a little off using curved lexan scissors but I think I’ll switch to a blade and go slowly. Perhaps try splitting it into two halves first. Share this post Link to post Share on other sites
Finnsllc 917 Posted July 30, 2020 @Badcrumble i did mine with a hobby knife, very gently and slowly 1 Share this post Link to post Share on other sites
Finnsllc 917 Posted July 30, 2020 @Badcrumble that whole leaxan part is really a challange. go way slow. the four parts that come off there are not the easiest to follow 1 Share this post Link to post Share on other sites
Wez-li 1790 Posted July 30, 2020 1 hour ago, ChrisRx718 said: Stuck the MST rims on my "accidental purchase" Wrangler Looks the part now. Ahhh yes, the good old "accidental purchase" . Share this post Link to post Share on other sites
