Willy iine 18806 Posted February 13, 2022 Finished the decals. Turned out okay I think. I’m going to let this dry overnight since I used distilled water and will go over it again with my heat gun tomorrow before reaming out the little holes for the wing. If my work does not kill me, I will start the chassis tomorrow. 7 Share this post Link to post Share on other sites
GeeWings 2830 Posted February 13, 2022 @Nikko85good work with the IKEA spares. Good to know there is a use for them as I keep everything as my wife always asks "why?" Sounds like a good breakthrough with the Hexes on the QD. What's your secret if I may ask?! Share this post Link to post Share on other sites
Frankster 2033 Posted February 14, 2022 8 hours ago, Willy iine said: I mean if you can achieve a nice even coat, layering different colors is no problem. If your coat is thick you will want to very lightly score the masking tape edges while removal.. but the whole purpose of using backing layers is to have a light coat so not sure if you need to. Maybe in the future if you only need basic colors (or want to make custom colors), you can look into acrylic paints you can just brush on. Then you can paint inside your room or bath room with the vent running if you need it. Acrylic polycarbonate paint (the one I use) have almost no scent compared to enamel/lacquer and is non-toxic. Sorry for the earlier grammar and spelling mistakes. Was half asleep when I typed it out. Body ended up 1 full white can + 1/2 can silver + 1/2 can black. So much for light coats of backing 🤦♂️. My OCD had me spraying more layers of black as I could still see layers of silver. I do need to look into acrylic polycarbonate paint and if it is available locally. Share this post Link to post Share on other sites
Re-Bugged 10151 Posted February 14, 2022 10 hours ago, topforcein said: personally i would apply as few as possible seeing the beautiful paint you have achieved should not be cover'd up 10 hours ago, Willy iine said: Yes me too, just enough decal accents only. You two have been talking to Mrs RB haven’t you? 🤔😉, that’s exactly what she said.. 1 1 Share this post Link to post Share on other sites
Willy iine 18806 Posted February 14, 2022 2 hours ago, Re-Bugged said: You two have been talking to Mrs RB haven’t you? 🤔😉, that’s exactly what she said.. Mrs.RB knows. 1 Share this post Link to post Share on other sites
GeeWings 2830 Posted February 14, 2022 Took the morning off to watch the Super Bowl and had planned to crack open the Blockhead Wild One so I could build as I watched but the game was too involved to look away from. I did order a couple of bits and pieces for later builds. MUST. STOP. BUYING 3 Share this post Link to post Share on other sites
SupraChrgd82 1425 Posted February 14, 2022 99% done with the Knightrunner. Now to install the RX and solder a connector to the ESC. 2 Share this post Link to post Share on other sites
TurnipJF 9192 Posted February 14, 2022 Recorded some lap counts for the postal racing using my TL-01LA and TB-03 JGTC-bodied cars. Despite the former running a 27t Reedy MVP and the latter a 13.5t Speed Passion MMM, their lap counts weren't dramatically different. These short courses seem to be great equalisers in terms of power. You don't need a fast motor to post a good result. 1 Share this post Link to post Share on other sites
mtbkym01 4008 Posted February 14, 2022 Ordered stainless steel screws, enough for a Wild One 1 Share this post Link to post Share on other sites
Nikko85 3454 Posted February 14, 2022 13 hours ago, GeeWings said: @Nikko85good work with the IKEA spares. Good to know there is a use for them as I keep everything as my wife always asks "why?" Sounds like a good breakthrough with the Hexes on the QD. What's your secret if I may ask?! I used two 7 to 12 mm 3D printed hex converters on eBay Straight onto the rear axle, going into a GF01 wheel. They widen the track with by about 5 cm, mainly due to the different offset of the two wheels. Front was trickier. When using the QD wheels the front track width was no far too short. I used an 15 mm long 8mm OD x 5mm ID aluminium spacer on the front axle, with 12 mm bearing inside the 12mm hex of the wheel and a nut on the outside to stop the wheel popping off. I find a 12x5 bearing works very well in a 12 mm hex wheel, with no other mods needed. I'll take some pictures this evening. Share this post Link to post Share on other sites
GeeWings 2830 Posted February 14, 2022 @Nikko85Good work! Look forward to seeing the pics! Share this post Link to post Share on other sites
alvinlwh 5895 Posted February 14, 2022 Received 2 of the biggest pinions I can find on ebay (got bigger ones coming from Aliexpress). Only the 44T one can fit, need to find some smaller spur gears. Wanted to see how far I can go before the silver can melts. Took the regeared MG Evo out for a test. On a very rough surface, about 2mph less than the app calculated. Maybe it is the surface or I am hitting the limits of the silver can. Share this post Link to post Share on other sites
Willy iine 18806 Posted February 14, 2022 I applied cement along all edges to seal the CF from moisture. Will give it a couple hours and start assembly.. 2 Share this post Link to post Share on other sites
Badcrumble 4204 Posted February 14, 2022 Nearly finished monsterizing the CR-01. Want to check servo alignment before fitting the rear bumper. Not sure about those shock angles but wanted to at least get it back on its wheels rather than be a pile of bits in the garage. 5 Share this post Link to post Share on other sites
Willy iine 18806 Posted February 14, 2022 @Badcrumble Coming together!! Those tires and wheels look so good on the CR01. Share this post Link to post Share on other sites
Busdriver 6209 Posted February 14, 2022 I found out today why I like this forum so much. Trust...... I entered into a transaction with a fellow member today and before I'd even had a chance to wrap the parcel up let alone sent it the money was in my bank. That means a whole lot to me. To the mystery member thank you. 4 Share this post Link to post Share on other sites
Badcrumble 4204 Posted February 14, 2022 2 hours ago, Willy iine said: @Badcrumble Coming together!! Those tires and wheels look so good on the CR01. Thanks @Willy iine. I think I need some shorter stand-offs / ballstuds at the top of the dampers, those are the ones that came with the shocks. I've got some other wheels / tyres coming that I think will suit it better but let's wait until I get a body on there. I have a little hard body (and paint and stickers) that I think would look really cute but I think the wheelbase will be too short, even with plenty of cutting. I did receive some vouchers for Modelsport which would go part way to a new JConcepts body and paint. Need better weather though... At some point I'll get wrenching on it again - I have an 8T 550 can to replace the silver can. 1 Share this post Link to post Share on other sites
silvertriple 3557 Posted February 14, 2022 Finally got my wheels on Thingiverse https://www.thingiverse.com/thing:5247223 And you may even use them with hex hub drivers, just in case you want them on something else than a Samurai 4 Share this post Link to post Share on other sites
Willy iine 18806 Posted February 14, 2022 Started the chassis.. This chassis is so quirky.. it’s CF, but has a lot of Tamiya goodness that is quite different from other CF dual decks I’ve built in the past from other brands. 1 Share this post Link to post Share on other sites
toyolien 4681 Posted February 14, 2022 Today I started the process of building yet another scale garage. I had to sell my last one as we were moving house. However, the move fell through and instead we've extended my garage, so I now a have room for a permanent home for a nice scale garage. It won't be as elaborate as before, but nonetheless, it'll still provide a nice back drop to build pics. Well, I hope so.... Here's the start of the 'slow progress' build. 7 Share this post Link to post Share on other sites
Frankster 2033 Posted February 15, 2022 @Badcrumble I am not familiar with CR-01. Looks like you painted the frame and change tires (clod buster?). Dampers look different too. Is the ride better with this suspension set up as it is more direct? Share this post Link to post Share on other sites
Frankster 2033 Posted February 15, 2022 all masked and painted. Headlights did not come with any masking. I applied masking tape to wax paper and then traced the light lens decal against the window (poor man’s light box). 1 can of white + 1/2 can of silver backing + 1/2 can of black backing. No issues with the darker colors peaking through as I was checking for evenness between the white coats. Could not fully score the window masking before removing and the edges are a little rough. The window frame decals should cover this up 8 Share this post Link to post Share on other sites
Trowa Jakuard 63 Posted February 15, 2022 I've been going though our warehouse stock and applying vehicle fitment checks to new and old tamiya part numbers in out database for our website and sales system Share this post Link to post Share on other sites
Badcrumble 4204 Posted February 15, 2022 Your Porsche is looking nice @Frankster. Are there four holes in the roof? Is it going to have a rack? The inspiration for the CR-01 comes from this thread The wheels and tyres are from an MST monster truck so retain the the standard hex size (Clod tyres are bigger with a wider hub to handle the forces). The car came to me second hand but I think the black chassis was stock on the Rock Socker. Whilst I believe that some real monster trucks did run divorced coil set-ups, I removed the complicated Tamiya cantilever springs / dampers for a cleaner, more traditional look (copying one of our esteemed TC members!). 1 Share this post Link to post Share on other sites
Willy iine 18806 Posted February 15, 2022 I redid the windshield decal as I did not like Tamiya’s tint decal..took me a while as I trial and errored a few different vinyls.. this one is automotive BMW vinyl in rich glossy black. Also started the masking for the tray. Will work on it some more during my breaks. 7 Share this post Link to post Share on other sites
