silvertriple 3557 Posted February 23, 2022 7 hours ago, GeeWings said: Looks great @16_Bit_Mr_J that metallic blue really elevates it I reckon. I have a soft spot for the Big Wig as it was the last car my brother purchased and 'shared' with me as kids before he moved away. One day I will own one! @silvertriplethat looks fun! Can you remind me again what software you are using. On the weekend, after some frustration as my wife and I were trying to visualise how our proposed renovation is going to look I decided to model a 3D visualisation. I started up the latest version of the 3D package I used to use most for technical geometry based modelling (Lightwave 3D). Safe to say it has moved on quite a bit in 10 years! I could barely remember how to build basic boxes let alone booleans and splines. I'm using Fusion 360... Not sure it is the right tool for a renovation visualization, however... Share this post Link to post Share on other sites
GeeWings 2830 Posted February 23, 2022 35 minutes ago, silvertriple said: I'm using Fusion 360... Not sure it is the right tool for a renovation visualization, however... No. I will stick to lightwave for that purpose. But lightwave isn’t great as a tool in a 3D print workflow due to the way it handles polygons. Though that might have changed too. Share this post Link to post Share on other sites
Grumpy pants 4485 Posted February 23, 2022 3 hours ago, Frankster said: @Grumpy pants Any photos you can share? There we go! Share this post Link to post Share on other sites
Busdriver 6209 Posted February 23, 2022 8 hours ago, Yoshimitsu said: Been procrastinating about doing this for an age... Half a job tonight, it's so much easier when you just have to stick them on rather than hand paint them.😬 Phew!!! For a moment I thought you meant the stickers not the window trim😂 2 Share this post Link to post Share on other sites
Busdriver 6209 Posted February 23, 2022 16 minutes ago, Grumpy pants said: There we go! 😍😍😍 1 Share this post Link to post Share on other sites
Grumpy pants 4485 Posted February 23, 2022 8 minutes ago, Busdriver said: 😍😍😍 Great model imo, easy to build, run and maintain. Good fun to run as well, simplicity is the key! 1 Share this post Link to post Share on other sites
Nikko85 3452 Posted February 23, 2022 As I'm sure I've bored you with enough of my QD trucks, here's another! This one is the QD chassis with a Tyco Bandit 9.6V body. Originally this body was going to go on the MF01x (like @OoALEJOoO) but now I've got those at 171 mm wheelbase, it's too long. I may leave the body as is, or paint as a King Cab, for a QD King Cab. Now I've converted the wheels to hex, I could also perhaps run very slightly smaller wheels. These are 115 mm OD tires (Pumpkin Standard) but going to 100 mm might work a little better? Or just leave as is, and make a king cab more of a monster. 3 Share this post Link to post Share on other sites
Busdriver 6209 Posted February 23, 2022 1 hour ago, Grumpy pants said: Great model imo, easy to build, run and maintain. Good fun to run as well, simplicity is the key! Very true and the hard body makes it fun to modify 1 Share this post Link to post Share on other sites
Frankster 2033 Posted February 23, 2022 3 hours ago, Grumpy pants said: There we go! Nice. For some reason thought it was a built kit 1 Share this post Link to post Share on other sites
Nikko85 3452 Posted February 23, 2022 1 hour ago, Nikko85 said: As I'm sure I've bored you with enough of my QD trucks, here's another! This one is the QD chassis with a Tyco Bandit 9.6V body. Originally this body was going to go on the MF01x (like @OoALEJOoO) but now I've got those at 171 mm wheelbase, it's too long. I may leave the body as is, or paint as a King Cab, for a QD King Cab. Now I've converted the wheels to hex, I could also perhaps run very slightly smaller wheels. These are 115 mm OD tires (Pumpkin Standard) but going to 100 mm might work a little better? Or just leave as is, and make a king cab more of a monster. Does anyone know the outside diameter of the King Cab tires please? I could then scale down from 1:10 to 1:14 to find something relatively scale. I wonder if Blitzer (90 mm?) tires could work well? There's a lot of truck under the body, but that's the case of the king cab too. Of course I could also look to modify the GF01, as that might allow the body to sit lower, but that would be 4WD. Share this post Link to post Share on other sites
Nikko85 3452 Posted February 23, 2022 I also went to the park and found the large flat gravel pitch was free! Both the MF01x were great. Pumpkin below certainly handled better with the wide stance and paddle tyres, but they were both fun to drive through the dirt. Share this post Link to post Share on other sites
Willy iine 18805 Posted February 23, 2022 All this talk about pumpkins, I decided I wanted to drive Willy’s PumpkinHead F100 too so I did this morning. 5 Share this post Link to post Share on other sites
Busdriver 6209 Posted February 23, 2022 2 hours ago, Willy iine said: All this talk about pumpkins, I decided I wanted to drive Willy’s PumpkinHead F100 too so I did this morning. That’s my favourite of your Willy’s 1 Share this post Link to post Share on other sites
16_Bit_Mr_J 201 Posted February 23, 2022 12 hours ago, Frankster said: I did the same as well with metallic blue. Looks much better and the metallic gives it a nice pop Looks wicked dude. I've got of a backlog on kits at the mo so the Bigwig is on the back-burner kinda 1 Share this post Link to post Share on other sites
Aerobert 2142 Posted February 23, 2022 7 hours ago, Nikko85 said: As I'm sure I've bored you with enough of my QD trucks, here's another! This one is the QD chassis with a Tyco Bandit 9.6V body. Originally this body was going to go on the MF01x (like @OoALEJOoO) but now I've got those at 171 mm wheelbase, it's too long. I may leave the body as is, or paint as a King Cab, for a QD King Cab. Now I've converted the wheels to hex, I could also perhaps run very slightly smaller wheels. These are 115 mm OD tires (Pumpkin Standard) but going to 100 mm might work a little better? Or just leave as is, and make a king cab more of a monster. That Tyco Bandit looks gorgeous. I would definitely leave it as it is. Body and wheel combo looks great. I think I need to look out for a Bandit and a QD chassis. Share this post Link to post Share on other sites
16_Bit_Mr_J 201 Posted February 23, 2022 If you know where the music is from then you also had a wicked childhood 2 Share this post Link to post Share on other sites
Grumpy pants 4485 Posted February 23, 2022 8 hours ago, Frankster said: Nice. For some reason thought it was a built kit I didn’t get as far as that 😂 Share this post Link to post Share on other sites
Grumpy pants 4485 Posted February 23, 2022 Just got great feed back from the buyer of my M07 💥 3 Share this post Link to post Share on other sites
naturbo2000 1271 Posted February 23, 2022 I joined and posted! But equally importantly I got the box of bits that had my old Madcap smushed into half an Optima as a tarmac basher back into the below (apologies for the pic cross-post). It's super tired and very floppy. But I'm pretty sure I'm still going to pick up a ball race set, some no-name oil filled shocks, replace the missing idler gear (maybe get a 3d printed version (!)) and see if I can't rebuild the diff. Oh and the steering play is absolutely shocking. Chassis is in one piece - some cracks around the front bolts, but the rear is immaculate (I think I used a plywood "plank" to save it after wearing through the previous 2). 2 Share this post Link to post Share on other sites
Willy iine 18805 Posted February 23, 2022 Okay so I placed an order for a NIB Avante 2011 body set with driver and everything. So basically you can all tell what happens when voices in my head start talking.. .. so what the heck am I going to do with just the body set.. can't use it on the Egress.. running it on a DF02 or TT02B would look odd.. hummmm... 2 Share this post Link to post Share on other sites
GeeWings 2830 Posted February 23, 2022 Just the start of the day here and I have a day off work so this morning I will finally do some kit building. Then this afternoon I'm heading out to inspect and test drive two real-life LandCruisers. One Fj40 which has been beautifully restored with a price tag to match. The other started life as a BJ40 but has been converted to petrol and part restored, there is lots still to do and from the pictures it might be too much of a project. Like Goldilocks I think neither is quite right but time will tell! Oh and having expressed very little interest in the TD4 one has come up for sale locally at a very good price. So I will spend the day convincing myself I shouldn't buy it! 1 Share this post Link to post Share on other sites
Kol__ 3377 Posted February 23, 2022 2 hours ago, naturbo2000 said: I joined and posted! But equally importantly I got the box of bits that had my old Madcap smushed into half an Optima as a tarmac basher back into the below (apologies for the pic cross-post). It's super tired and very floppy. But I'm pretty sure I'm still going to pick up a ball race set, some no-name oil filled shocks, replace the missing idler gear (maybe get a 3d printed version (!)) and see if I can't rebuild the diff. Oh and the steering play is absolutely shocking. Chassis is in one piece - some cracks around the front bolts, but the rear is immaculate (I think I used a plywood "plank" to save it after wearing through the previous 2). Awesome mate, a true classic and one of my favs. Make sure to start up a build thread on that puppy if you haven't already Share this post Link to post Share on other sites
Kol__ 3377 Posted February 23, 2022 23 minutes ago, GeeWings said: Oh and having expressed very little interest in the TD4 one has come up for sale locally at a very good price. So I will spend the day convincing myself I shouldn't buy it! Buy it bud, you're worth it Share this post Link to post Share on other sites
Nikko85 3452 Posted February 23, 2022 5 hours ago, Busdriver said: That’s my favourite of your Willy’s Mine is longer 2 1 Share this post Link to post Share on other sites
naturbo2000 1271 Posted February 23, 2022 4 minutes ago, Kol__ said: Awesome mate, a true classic and one of my favs. Make sure to start up a build thread on that puppy if you haven't already I really mustn't. Otherwise it'll end with me getting carried away and grafting in a carbon fibre astute chassis. I've already seen that fibre-lyte do one and I reckon it's an easy swap. 1 Share this post Link to post Share on other sites
