Grastens 2795 Posted February 8, 2017 3 hours ago, GooneyBird said: My end game, just so you know, with this car, is to have a retro '70s/'80s Le Mans-style Group C body on there. Just to annoy all the wedge-shaped Pro10s and 1/12th scale cars. I like the sound of that a little too much But at least you are not going all Group 6 (read: hard plastic as in the '70s) on them for now: (originals are expensive, but re-releases are kicking around online) By the definition of the 24 Hours of LeMons (and I do mean LeMons), such a setup would be of "palpable effluence." And as a fan, I look forward to seeing what your setup will look like finished Share this post Link to post Share on other sites
GooneyBird 938 Posted February 8, 2017 8 minutes ago, Grastens said: I like the sound of that a little too much But at least you are not going all Group 6 (read: hard plastic as in the '70s) on them for now: (originals are expensive, but re-releases are kicking around online) By the definition of the 24 Hours of LeMons (and I do mean LeMons), such a setup would be of "palpable effluence." And as a fan, I look forward to seeing what your setup will look like finished Oohhh, a LeMons-themed body shell! Something like a touring car body with a rubber chicken on it or whatever. And in terms of "finished setup", well, that's pretty much it, aside from a body shell (currently a horrendously painted hand-me-down...thing). That car consists of nothing more than an F104 rear pod, an F103 front suspension, and some electronics in the middle. No center shock, no roll tubes, nothing. Share this post Link to post Share on other sites
Jason1145 3986 Posted February 8, 2017 Got some tyres off some Hornet wheels.... this was an effort. Share this post Link to post Share on other sites
firefoxussr 482 Posted February 8, 2017 the plot thickens .... the seller of my Active Hobby Lotus has an uncut body... perfect for mold-making 1 Share this post Link to post Share on other sites
Grastens 2795 Posted February 8, 2017 3 hours ago, GooneyBird said: Oohhh, a LeMons-themed body shell! Something like a touring car body with a rubber chicken on it or whatever. And in terms of "finished setup", well, that's pretty much it, aside from a body shell (currently a horrendously painted hand-me-down...thing). That car consists of nothing more than an F104 rear pod, an F103 front suspension, and some electronics in the middle. No center shock, no roll tubes, nothing. Oh yes And having noticed the spartan nature of the car, I do mean the shell Share this post Link to post Share on other sites
Ian_Gsi16V 533 Posted February 9, 2017 13 hours ago, Jason1145 said: Got some tyres off some Hornet wheels.... this was an effort. IIRC, if you split the wheels the two halves just fall out of the tyre Bit late now but something to remember when you put it back together 1 Share this post Link to post Share on other sites
Rb4276 803 Posted February 9, 2017 Added the suspension block weight to my dn-01 and also added new jcpncept ribs Share this post Link to post Share on other sites
Jason1145 3986 Posted February 9, 2017 10 hours ago, Ian_Gsi16V said: IIRC, if you split the wheels the two halves just fall out of the tyre Bit late now but something to remember when you put it back together How do you mean split the wheels... the tyre has to stretch over the middle piece, this is the hard bit you are trying to make easier? Getting the front and rear pieces on/off are easy, its that central piece that's the pita. So putting it back together I still have to stretch the tyre over the central part. Share this post Link to post Share on other sites
i_am_scarecrow 913 Posted February 9, 2017 Took the Madbug out for a blast today 2 Share this post Link to post Share on other sites
Grastens 2795 Posted February 10, 2017 "Ladies and gentlemen, the Avante is back!" - Tamiya America, 2011 And so presently is mine, having been rebuilt over the past few days following a stripping-down of the main chassis and gearboxes and subsequent cleaning. Having finished much of the reassembly already, I started out today with some dried and clean shock absorbers: I was surprised none of the seals were visibly bad, as they all held oil and I was able to build them up - although some needed more tries than others. They are definitely used; notice the chewed-up bottom eyelet on one of the rears and the worn-off anodizing. They are tired, but functional: In the end, everything mostly needed a good cleaning, but I swapped out the SR300 receiver for a SR200WP just in case. The collars on the front dampers also came from a spare parts tree. Wiring was redone, and the cleaned gears received what was left of my scant ceramic grease supplies. How I fed the gearboxes with molybdenum grease before is astounding, as it now runs as smoothly as it has since it first ran, with the gearboxes definitely lower on friction with the thinner ceramic grease: There were fewer new parts than I wanted to put in (I have a cache of metal ball ends, for instance), with new parts being limited to swapped bearings, front and rear differentials (old ones will be rebuilt, most likely), shock collars, and receiver. Even the outdrives are the original pieces. But the whole thing, showing wear yet much fresher than usual, went back together, which is what I am happiest about: The wheels could use a scrub, though... The resurrection of my Avante and my Photobucket account coincide with each other as Tinypic is inexplicably non-functional now. I am more excited about getting a run in with the RC car than giving the image-hosting site a proper spin, though! Going through my old build records turned up a short-lived build journal. Within it were my first impressions of this special car when I got to take it on its first run. The memories of a ground-bound spaceship whistling past might be resurrected once I find a place to get it running... 1 Share this post Link to post Share on other sites
iluvmud 812 Posted February 10, 2017 LOTS!!!!!! Finished my M05 body- for the M05 I want to keep.... still need to paint the wing and mirrors and get the wheels I want. Finished Long Haul (well, need someone to make me some tiny decepticon decals and need to hit up the LHS for some black paint to do the grill and exhaust stacks) Polished this turd....... to get ready to list it on ebay (not really a turd, but the body was pretty jacked up so I made it work by using standard touring car wheels/tires and adding CVA shocks and bearings) And made more impulse buys.......2 cars and a vintage motor- BUT HEAR ME OUT!!!! Theyre too good a deal to pass up all from same seller in japan and he even has thrown in a surprise gift in the package. and they are.... drum roll please........ Car #99 in pretty dang good condition and oddly enough it looks like it's been merged with CAR #100 (see the top force body mount left on the chassis.....) Then its Tam 58169 also in pretty good condition with a slew of mods And lastly a nice condition Dynatech 02H motor Now to start selling stuff on ebay to recoup the funds I spent on this.... (really wasnt much but wasnt planned.....) 4 Share this post Link to post Share on other sites
Crash Cramer 617 Posted February 10, 2017 Looks like someone will be asking me about any TA series parts I might have still. Randy, what wheels are you after for that PINK MASHER??? I might have a set for you here. nice buys Share this post Link to post Share on other sites
iluvmud 812 Posted February 10, 2017 14 minutes ago, Crash Cramer said: Looks like someone will be asking me about any TA series parts I might have still. Randy, what wheels are you after for that PINK MASHER??? I might have a set for you here. nice buys HPI m-series wheels which should by dyeable , or any yellow M series wheels you got Share this post Link to post Share on other sites
Crash Cramer 617 Posted February 10, 2017 YELLOW??? Well, now you got me, I have chrome. HPI series, I had some skinny spoke HPI wheels, but they too were chrome. Share this post Link to post Share on other sites
iluvmud 812 Posted February 10, 2017 1 minute ago, Crash Cramer said: YELLOW??? Well, now you got me, I have chrome. HPI series, I had some skinny spoke HPI wheels, but they too were chrome. lol yeah... you didnt strike me as someone who would own yellow wheels...... I was surprised you have nothing on the fighter buggy RX though.... lol Maybe something from a mad bull, rookie rabbit? Share this post Link to post Share on other sites
ernieks 130 Posted February 10, 2017 3 hours ago, iluvmud said: If you are interested in sell or trade on that TA-02 Mustang, I will be really interested. Great example! ernieks Share this post Link to post Share on other sites
mike_o 35 Posted February 10, 2017 Poll: If you had one how often would you update it ? Could I have more choice than "several times a day", pls? Share this post Link to post Share on other sites
stamatis 84 Posted February 10, 2017 I spent the day as every other day of this week taking pics for my TAMIYA Facebook page, which is ready now! https://www.facebook.com/Stams-Tamiya-RC-1713880342209617/ Share this post Link to post Share on other sites
Badcrumble 4204 Posted February 10, 2017 I set aside some RC time today. Set an achievable goal of my WW2 wheel conversion and adding some of the blong from my recent Banzai lucky bag purchase. Before... After... You can't see the front upper links or motor guard in this pick and it is a poor angle for a decent view of the new nudge bars! The skid plate/nudge bars are a bit wonky as the plastic they attach to have had a fair few impacts (me and the previous owner!) The upper links took a while to set up - at the suggested length, there was an awful lot of camber! Unfortunately, electrical gremlins meant no running. I need to re-release the instructions for my Tx - when I find them! Share this post Link to post Share on other sites
firefoxussr 482 Posted February 10, 2017 15 hours ago, iluvmud said: Finished Long Haul (well, need someone to make me some tiny decepticon decals and need to hit up the LHS for some black paint to do the grill and exhaust stacks) I used these Decepticon stickers on my short course truck for racing, never had them come off. http://www.ebay.com/itm/G1-Decepticon-Symbol-Insignia-Logo-Sticker-Decal-Sheet/112199166882 Share this post Link to post Share on other sites
Munchbox 100 Posted February 11, 2017 Today I messed around with adding LEDs to my Lunchbox as headlights. I didn't realize that the receivers channel 3 doesn't do the switching on its own so I gutted an old steering servo and used the controller inside it to manage the on/off voltage for the lights. A little silicone to hold the LEDs in the buckets and we're off. Now for the taillights, which will be interesting since the Lb shell has stickers for the taillights rather than any kind of real lens... Share this post Link to post Share on other sites
iluvmud 812 Posted February 11, 2017 16 hours ago, ernieks said: If you are interested in sell or trade on that TA-02 Mustang, I will be really interested. Great example! ernieks Pm me what you got to trade, I might bite! Share this post Link to post Share on other sites
iluvmud 812 Posted February 11, 2017 5 hours ago, firefoxussr said: I used these Decepticon stickers on my short course truck for racing, never had them come off. http://www.ebay.com/itm/G1-Decepticon-Symbol-Insignia-Logo-Sticker-Decal-Sheet/112199166882 You're the man!!!! Ordered! 1 Share this post Link to post Share on other sites
Blista 1519 Posted February 11, 2017 Had some good weather today so I took the opportunity to paint a CRX shell and glued some wheels between coats. I agonized over what colour combination to paint the shell. I was set on metallic red on top with silver below but at the last second went white over gun metal. If I can get the decals on without making a mess of it I have some wheels in mind and a cockpit set to complete the look. 1 Share this post Link to post Share on other sites
Crash Cramer 617 Posted February 11, 2017 2 minutes ago, Blista said: Had some good weather today so I took the opportunity to paint a CRX shell and glued some wheels between coats. I agonized over what colour combination to paint the shell. I was set on metallic red on top with silver below but at the last second went white over gun metal. If I can get the decals on without making a mess of it I have some wheels in mind and a cockpit set to complete the look. Looking great, you ought to do the red one for the Japanese version of The Italian Job with your other two. Good to see another one or two and good luck with those blasted decals, I still remember doing mine. Sure wish I had known then that if you go by decal number in sequence from smallest number to larger number when wrapping windows and the like, it is going to go much smoothly rather than guess which ones layer over the other, a minor detail I don't recall the instructions pointed out, TamiyaManDan told me about that from a book he read that the decals are intended to be put on by sequence starting at #1 through to the last decal. I NEVER knew that, 30 plus years now!!! Share this post Link to post Share on other sites
