rcracerpete 0 Posted September 3, 2007 Hello, i am fitting standard shocks with crp coilover kit and taking away the rear torsion bars, but how do i get a piece of brass tube to fit in thew front of the rear arms, as this is attached to the rear torsion bars? Thanks for any help, Pete. Share this post Link to post Share on other sites
Blacque Jacque 4 Posted September 3, 2007 I bolted mine to prevent them bending in a big crash. I used an M4 bolt & some 6mm OD aluminium tube as a bush with a couple of washers as shims & a nyloc nut to stop it all escaping. Have a close look at the pics of my Ranger. I can post some better closeups tonight if you want a better look. Share this post Link to post Share on other sites
dready 0 Posted September 4, 2007 I used an old screwdriver (nice and hard chrome vanadium and perfect diameter 6mm) Cut down to 18mm lengths A simple fix but works a treat and you can make loads out of just one old tool ;-) Share this post Link to post Share on other sites
Shodog 1835 Posted September 5, 2007 easiest fix is to just bend the torsion bar and pull it out of the brass piece. RCH made a vintage hop up that replaces that piece. I used them on my aftermarket buggy http://www.tamiyaclub.com/showroom_model.a...40879&id=34 Share this post Link to post Share on other sites
KEV THE REV 2319 Posted September 5, 2007 Hello, i am fitting standard shocks with crp coilover kit and taking away the rear torsion bars, but how do i get a piece of brass tube to fit in thew front of the rear arms, as this is attached to the rear torsion bars?Thanks for any help, Pete. Hi Pete , i use B+Q brass rod , i cut it to length , finish the ends, and its perfect Share this post Link to post Share on other sites
Blacque Jacque 4 Posted September 5, 2007 Hi Pete , i use B+Q brass rod , i cut it to length , finish the ends, and its perfect Gotta be careful mixing brass & alloy, they have a tendency to bind together & seize up . Share this post Link to post Share on other sites
KEV THE REV 2319 Posted September 5, 2007 Gotta be careful mixing brass & alloy, they have a tendency to bind together & seize up . No problems so far - but thanks for the pointer ,but if you want to use alu rod Pete ,they sell that too Share this post Link to post Share on other sites
cherrybomb 0 Posted September 10, 2007 I sell these for 10 a set if you're interested. Share this post Link to post Share on other sites
