Well, i have a TT01, i got a 27 turns motor in it, runs just fine, but some TC members allways say the TT01 will have problems with faster motors, but i think it can handle the brushless just fine... allthough its plastic its notlike it falls apart all the time..
mattijn
quote:
id="quote">id="quote">
Not true at all.
Just keep in mind you won't be able to change the gear ratio too much.
I think if you have the alu prop shaft, and ball bearings then the car should be fine.
The plastic dog bones are a problem, so you should get alu ones.
Then I think it should be pretty much ok with a hotter motor.
quote:
Originally posted by thecrow2k
doesn't anyone run a brushless in there tamiya tl01, tb01, tt01 or any other tamiya touring car
Novak SS5800 & SS4300 runs very nicely in a TL01. Gearing with the smallest pinion should suit it quite well for general bashing.
I have SS5800s in the EvoIII and 1/12 EvoIII-mini.
in the manual for the ss5800 it says use the stock gearing your kit came with lol
personnally i just go up a few teeth and its still cool and alot better performance
might just be me tho because it makes sense lower turn lower gearing
ahwell lol
