Hi all,
I am at the build stage of my 1/16 sherman where i have to program the DMD.
However even though i have hooked up the electronics as per the instructions i have an annoying problem before i start. :(
Instructions state turn on transmitter and DMD. Press reset until alternating red/green flashing leds. They only flash amber together and the reset just pauses the flashing...Help!
Whats up? Any ideas?
If the lights are flashing amber then either the transmitter or receiver is not working, or the crystals are mis-matched. What it means is that the receiver is not getting a signal from the transmitter.
Check your batteries and crystals. If necessary try plugging some servos into the receiver and see if you can get them to work.
Check that all the plugs and connectors are plugged into the right sockets.
